Old 02-23-2012, 10:37 AM   #1
Default Discussion: Heart rate measurement from fingertip. Part 1. Schematic
Introduction Heart rate measurement indicates the soundness of the human cardiovascular system. This project demonstrates a technique to measure the heart rate by sensing the change in blood volume in a finger artery while the heart is pumping the blood.
More: Heart rate measurement from fingertip. Part 1. Schematic
Old 02-23-2012, 10:37 AM   #2
Allam88
Allam88 is on a distinguished road
How to increase the max. Measurable heart rate than 150
Allam88 is offline   Reply With Quote
Old 02-24-2012, 12:42 PM   #3
Allam88
please can u answer me about the Alternative of the ic u used that i cannot find it in my country .....
Old 02-26-2012, 10:36 PM   #4
MCP602 - 2-Ch Op Amp - LMV358 or MCP603/MCP604 - 4-Ch Op Amp.
PIC Microcontroller - PIC16F628A - you can use PIC16F84, but you need to change the firmware...
Old 02-29-2012, 06:17 PM   #5
Allam88
thanx Vadzz
please can u tell me how to increase the range of pbm that could be sensed than 150 ...
Old 03-06-2012, 05:02 PM   #6
Allam88
ok can i use lm358 insted of lmv358?????????????
Old 03-09-2012, 07:50 PM   #7
LMV358 - Dual General Purpose, Low Voltage, Rail-to-Rail Output Operational Amplifier
and
MCP602
Old 06-02-2015, 04:26 PM   #8
sherry
sherry is on a distinguished road
in the schematic why u have connected base of BC547 to pin RA3?
if we are using pic16f877a then where we connect base of BC547?
sherry is offline   Reply With Quote
Old 06-03-2015, 09:08 AM   #9
Base of BC547 connected to port RA3 (PIC16F628A pin 2: RA3/AN3/CMP1). This is IR transmit circuit.
If you use PIC16F877A - connect base of BC547 to pin 5 (RA3/AN3/Vref+).
In general, the base of the transistor can be connected to any port, but not forget to make the appropriate changes in program.
Old 06-03-2015, 02:55 PM   #10
sherry
thanx ...i am using two led's IR and RED,and to drive that giving delay to both the leds,so what are the pins i can use? can i use PORT E pins also?and i have to give delay at base of BC547 OR other end of led?
Discussion: Heart rate measurement from fingertip. Part 2. Software Radiolocman Robot Projects and Advices 11 05-21-2015 07:42 PM
Discussion: Heart rate measurement from fingertip. Part 3. References, notes, using the device. Radiolocman Robot Projects and Advices 1 02-18-2012 11:57 AM
