Old 01-18-2013, 08:45 PM   #1
Default Discussion: Field Strength Meter for 2.4 Ghz Wireless LAN
John Samin The original diode in the Microwave detector has been hard to find. I have found a supplier for the diodes....
More: Field Strength Meter for 2.4 Ghz Wireless LAN
Old 01-18-2013, 08:45 PM   #2
n0lkk
n0lkk is on a distinguished road
Thanks for posting this. But I have to ask could be could changing the polarity of the antenna be as simple at rotating the meter it's mounted on 90 degrees? Also be it a DMM or VOM the apparent sensitivity is going to depend on the input impedance of the meter. Connecting it to a panel meter directly without amplification isn't likely going to work at these flea fart signal levels.
n0lkk is offline   Reply With Quote
Discussion: Wireless Keylogger - Do It Yourself! Part 1 Radiolocman Robot Projects and Advices 4 05-30-2012 03:54 AM
