Old 08-08-2013, 02:38 PM   #1
Default Discussion: AVR programmer Olimex AVR-PG1
AVR-PG1 - Serial port (RS232) PONY PROG compatible AVR programmer with STKxxx 10 pin ICSP connector. AVR-PG1 is the most simple and inexpensive AVR programmer on the market.
More: AVR programmer Olimex AVR-PG1
Old 08-08-2013, 02:38 PM   #2
swamyvarma
swamyvarma is on a distinguished road
my PC doesnt have a RS232 pin so i have to connect through usb to serial converter, can you suggest me an alternative for AVR- PG1 programmer for programming AVR controllers
swamyvarma is offline   Reply With Quote
Old 08-13-2013, 05:26 PM   #3
Maybe in this case, the best solution would be to build programmer for AVR microcontroller with USB interface... One simple example - AVR910...
Discussion: ÁProg - tiny, fast, portable AVR programmer with SD. Part 3. Software, Memory card, files, Firmware update, Demonstration Radiolocman Robot Microcontrollers (MCU) 2 03-25-2013 09:40 PM
Discussion: Cheap Sound Sensor for AVR Radiolocman Robot Microcontrollers (MCU) 2 05-13-2012 07:52 PM
Discussion: AVR TV terminal Radiolocman Robot Microcontrollers (MCU) 2 01-03-2012 07:40 PM
Discussion: ICSP serial port dongle programmer Olimex PIC-PG1 Radiolocman Robot Projects and Advices 1 07-06-2011 07:57 AM
Discussion: ATMEL AVR ISP Programmer that Works with AVRStudio4 Radiolocman Robot Microcontrollers (MCU) 2 05-12-2011 06:55 AM
