Old 05-12-2016, 05:56 PM   #1
onklen
onklen is on a distinguished road
Default Relay or MOSFET for 24V and 2A
I'm working on a small project where I want to use my Raspberry PI to turn on/off a power resistor for temperature control. I'm looking at a maximum of 50W and I have a 24VDC power supply so I will be looking at approximately 2A through the power resistor.
Would this design be best by using a MOSFET to activate a 24VDC relay or would it be fine to simply use a MOSFET that would be rated for 2A and skip out on the relay?
I'm hoping that I can drive it directly from the Raspberry PI so naturally the gate current would need to be kept low as well as the gate voltage as I won't have more than 5V.
Any good advices on a specific MOSFET that might be handy?
onklen is offline   Reply With Quote
Old 06-03-2016, 09:01 AM   #2
DRN_231
DRN_231 is on a distinguished road
A simple N MOSFET will do.
there are thousands.
Look for:
* VDS > 30V (better 40V)
* V_GS_TH < 3V
* R_DS_ON < 50mOhms (At 4.5V V_GS or below)
DRN_231 is offline   Reply With Quote
Old 06-13-2016, 08:41 PM   #3
If you planned to supply the relay coil with the same voltage already used by logic devices, I agree to prefer an N-Mosfet. Relays in general generate expressive spike on power bus during On/Off switching.
SOI MOSFET Radiation at High Frequency ravicoolit Beginners 0 01-20-2016 05:05 PM
Regulating transistor mosfet Jon Beginners 2 08-06-2015 01:56 PM
Discussion: Robot shield for Arduino. Part 1 - Hardware and Schematic Radiolocman Robot Microcontrollers (MCU) 1 05-13-2014 05:17 PM
Construction of schemes for audio and video inputs eletmoraes Projects and Advices 1 11-05-2013 04:04 PM
Discussion: 300 Watt MOSFET Real HI-FI Power Amplifier Radiolocman Robot Projects and Advices 1 03-28-2012 07:55 AM
