Old 01-16-2017, 08:10 PM   #1
Default Discussion: Op Amps Make Precision Clipper, Protect ADC
Thomas Mosteller, Aaron Schultz, Linear Technology Electronic Design A simple op amp clipping circuit can limit input-voltage excursions into an ADC, thus preventing input overload and possible damage to the converter. It can be a challenge to match the voltage range of an analog signal to the input range of an analog-to-digital converter (ADC).
More: Op Amps Make Precision Clipper, Protect ADC
Old 01-16-2017, 08:10 PM   #2
SiddharthGajjar
SiddharthGajjar is on a distinguished road
A very interesting article. The dynamic range of the ADC is determined by its voltage reference source, which may not exceed the supply voltage of the ADC
In other words, the dynamic range and the resolution of the ADC does not depend on the input signal.
SiddharthGajjar is offline   Reply With Quote
ADC using DMA in STM32F105, zero value alibarghi Microcontrollers (MCU) 0 01-09-2016 03:54 PM
Discussion: Implementing Discrete Fourier Transform in Atmega32 to make an audio spectrum analyzer Radiolocman Robot Projects and Advices 1 05-21-2015 04:13 PM
Discussion: Build an op amp with three discrete transistors Radiolocman Robot Projects and Advices 1 11-04-2014 01:42 PM
Discussion: Precision capacitance meter Radiolocman Robot Projects and Advices 1 10-20-2014 11:20 AM
Discussion: Additions Boost Fault-Protected Current Limiter Precision At Higher Supply Voltages Radiolocman Robot Projects and Advices 1 07-08-2014 05:46 PM
