Old 01-18-2017, 05:20 PM   #1
Default Discussion: Instrumentation amp makes an accurate transimpedance amp too
Stefano Salvatori EDN Transimpedance amplifier circuits are often used to convert photodiode current to a voltage signal. In the conventional transimpedance amplifier schematic of Figure 1, the current-to-voltage conversion factor is given by the value of the op-amp feedback resistor RF.
More: Instrumentation amp makes an accurate transimpedance amp too
Old 01-18-2017, 05:20 PM   #2
vbsai
vbsai is on a distinguished road
The idea is good, but a lot of photodiodes required for normal operation of the reverse bias voltage (5 and up). In a classic transimpedance amplifier is implemented elementary. How to do this by using the instrumentation amplifier?
vbsai is offline   Reply With Quote
Old 01-20-2017, 06:46 PM   #3
After reading the article also asked the question. Here, the allowable voltage for the reverse bias of the photodiode is really limited by the characteristics of the specific amplifier. But the author does not say that his idea/scheme is applicable for all types of sensors.
Cheap & simpe Arduino projects ??? tracert Beginners 1 10-17-2015 09:40 AM
Capacitors & Resistors in Amplifiers DRN_231 Beginners 1 08-28-2015 06:58 PM
Power amp fan trouble Jon Beginners 0 07-11-2015 09:52 AM
Discussion: 555-based class-D headphone driver makes great practice amp Radiolocman Robot Projects and Advices 1 06-11-2015 02:18 PM
Discussion: Build an op amp with three discrete transistors Radiolocman Robot Projects and Advices 1 11-04-2014 01:42 PM
