Old 01-30-2017, 07:10 PM   #1
Default Discussion: Cost Effective Driving of Standard LEDs from 10VDC up to 110/230VAC with Current Limiting Diodes - Flicker Free!
Diotec Semiconductor Standard LEDs are widely used for all kind of lighting purposes such as optical indicators and signal lights, marking lights, display backlights, interior and furniture lighting and much more. New approaches even use standard LED arrays to replace fluorescent lights (“neon tubes”).
More: Cost Effective Driving of Standard LEDs from 10VDC up to 110/230VAC with Current Limiting Diodes - Flicker Free!
Old 01-30-2017, 07:10 PM   #2
ricperes
ricperes is on a distinguished road
Yes, it is. At the same time that housing SMA and SMB was firing a "real" watt, on the PCB around the pads of copper should be more than 3-4 times the square of the buildings of the diodes. Otherwise, the maximum allowed in the Datasheet power levels with heat sink only through the tracks of an imminent overheating.
ricperes is offline   Reply With Quote
Use of IR2110 for three phase Full bridge IGBT driving jean12 Projects and Advices 3 01-10-2016 07:09 PM
110 to 12 volts reduction DRN_231 Beginners 1 10-16-2015 05:05 PM
Driving a 12 pins LED display wjoifeh Microcontrollers (MCU) 0 09-17-2015 05:37 PM
Discussion: Driving an LED with or Without a Resistor Radiolocman Robot Projects and Advices 1 11-18-2012 04:25 PM
