Old 03-12-2017, 06:25 PM   #1
Default Discussion: Isolated circuit monitors ac line
David Williams EDN The circuit in Figure 1 provides a low-cost, isolated ac-line monitor that measures ac-line-voltage level and has some other unique capabilities. The analysis of the circuit is straightforward: When the ac input, VIN, is positive relative to neutral, you apply it to the network comprising R1, R2, D1, and the LED in optocoupler IC1.
More: Isolated circuit monitors ac line
Old 03-12-2017, 06:25 PM   #2
The first thing that was zasomnevalas. Did I detector voltage transition through zero, also on the basis of the time of on/off of the optocoupler, and noticed that the my scheme is considerably affected by noise on the mains. Probably in this scheme will be a significant jitter due to noise in the network. Need hardware filtering of signal or software averaging measurement, or both
Old 03-20-2017, 10:27 AM   #3
Too complicated dependence of the pulse width of the voltage requires the use of a microprocessor and individual calibration of each meter. These things I can not afford as many radio Amateurs. Did the synchronization network: a step-down trance, with its windings on the active bandpass filter on OU, then the formers are positive and negative polarity, the formers at the front and a decline in the correct combination.
AC Sin wave to RCL circuit rapid Projects and Advices 0 06-09-2016 06:43 PM
AC to DC power supply mark Projects and Advices 0 11-17-2014 06:13 PM
Discussion: Automatic night-light feeds directly from the ac line Radiolocman Robot Projects and Advices 1 01-04-2014 04:20 PM
Discussion: One I/O line drives shift register with strobe. Part 1 - Schematic Radiolocman Robot Microcontrollers (MCU) 1 11-11-2013 12:18 PM
Discussion: Drive 16 LEDs with one I/O line Radiolocman Robot Microcontrollers (MCU) 4 08-23-2012 11:26 AM
