Old 03-20-2017, 10:30 AM   #1
Default Discussion: Simple Circuit Overcomes MOSFET Gate-Threshold Voltage Challenge
Sajjad Haidar Electronic Design When a MOSFET or IGBT gate-threshold voltage is higher than the available drive voltage, it's standard to use an op amp or other driver to bridge the difference. This circuit uses a basic optocoupler plus a few simple passive components to achieve the required results.
More: Simple Circuit Overcomes MOSFET Gate-Threshold Voltage Challenge
Old 03-20-2017, 10:30 AM   #2
Plus the gate must be relative to the source. You have a paddle hanging in the air in DC.
Discussion: MOSFET-based Joule Thief steps up voltage Radiolocman Robot Projects and Advices 1 02-07-2017 05:35 PM
Discussion: Short-Circuit Protection in DC Low-Voltage Systems Radiolocman Robot Projects and Advices 2 02-29-2016 09:02 PM
Need a simple latch circuit using logic gates Anatoly Projects and Advices 1 11-16-2015 02:44 PM
Discussion: Simple circuit indicates a low battery Radiolocman Robot Projects and Advices 2 02-10-2015 05:37 PM
Discussion: Simple Circuit Communicates Over Low-Voltage Power Lines Radiolocman Robot Projects and Advices 1 12-01-2013 05:41 PM
