Old 04-05-2017, 10:02 AM   #1
April155
April155 is on a distinguished road
Default Why does my LM386 chip act a bit too lively and what should I do?
I'm trying to design a superhet radio receiver that can be built up in sections, and now I met some problems.
The receiver is based on the AN602 double-balanced mixer IC, with the big brother of the ZN414 (the 10-transistor radio chip), the ZN416, employed as an IF amplifier, coupled with a standard LM386 audio stage . Power-supply requirements are 9 to 12 volts dc at 10 mA average (up to 30 mA at full volume).
As the LM386 is almost a standard chip for audio use, the only caution revolves around the 10-mF gain-setting capacitor. But what should I do if my LM386 seems a bit too lively?
Also, do you know how to enable the reception of SSB signals? Do I need other designs?
April155 is offline   Reply With Quote
Discussion: Smart Chip Tells You How Healthy Your Battery Is Radiolocman Robot Projects and Advices 2 08-06-2016 12:38 PM
TDA7052A and LM386 in low voltage power amp designs Cjuried Projects and Advices 3 01-21-2016 12:31 PM
Discussion: One-chip 1110 LED matrix. Radiolocman Robot Microcontrollers (MCU) 1 05-17-2015 12:48 PM
Radio receiver on a chip TDA7000 mark Beginners 2 11-22-2013 12:56 PM
Discussion: The smallest handheld automatic one-chip AVR-based DC voltmeter Radiolocman Robot Microcontrollers (MCU) 3 10-23-2012 09:53 PM
