Old 04-19-2017, 02:48 AM   #1
Default Discussion: Simple reverse-polarity-protection circuit has no voltage drop
Aruna Rubasinghe EDN Common methods of reverse-voltage protection employ diodes to prevent damage to a circuit. In one approach, a series diode allows current to flow only if the correct polarity is applied (Figure 1).
More: Simple reverse-polarity-protection circuit has no voltage drop
Old 04-19-2017, 02:48 AM   #2
jasen42
jasen42 is on a distinguished road
EDN fails again, with the supply reversed semiconductors and capacitors in the load conduct before the relay can switch. if you're lucky the relay switches before permanent damage is done
jasen42 is offline   Reply With Quote
Discussion: Simple Circuit Overcomes MOSFET Gate-Threshold Voltage Challenge Radiolocman Robot Projects and Advices 1 03-20-2017 10:30 AM
Discussion: Short-Circuit Protection in DC Low-Voltage Systems Radiolocman Robot Projects and Advices 2 02-29-2016 09:02 PM
Protection circuit for Li-ion batteries tracert Projects and Advices 2 07-26-2015 11:32 AM
Discussion: Simple Circuit Communicates Over Low-Voltage Power Lines Radiolocman Robot Projects and Advices 1 12-01-2013 05:41 PM
Discussion: Simple Reverse Polarity Protection Radiolocman Robot Projects and Advices 1 11-27-2012 11:46 PM
