Old 05-08-2017, 12:04 PM   #1
DRN_231
DRN_231 is on a distinguished road
Default ATmega328 High Voltage Programming
Hi All! Someone tried to save atmega328 with high voltage programming? I use the AVR Dragon to save 20 microcontroller with a locked fuse! |About I signed up on the adapter to connect the device I followed Devicesheet SCKT3200D2, but I'm not sure of the connections, because it specifies connections only 28 pin devices. So I made my own cross-table (attached).
DRN_231 is offline   Reply With Quote
Old 05-16-2017, 06:12 PM   #2
All the connections appear to be correct.
16 Bit LCD programming Anatoly Microcontrollers (MCU) 1 12-10-2015 04:28 PM
Programming an EEPROM tracert Projects and Advices 1 11-28-2015 08:14 AM
Discussion: Microcontroller drives piezoelectric buzzer at high voltage Radiolocman Robot Microcontrollers (MCU) 1 09-07-2014 02:05 PM
Discussion: Microcontroller drives piezoelectric buzzer at high voltage through one pin Radiolocman Robot Projects and Advices 1 12-16-2013 02:30 PM
Discussion: Mini High-Voltage Generator Radiolocman Robot Projects and Advices 2 07-07-2011 12:40 PM
