Old 05-23-2017, 06:48 PM   #1
hamid.abbaszadeh
hamid.abbaszadeh is on a distinguished road
Default ARM CMSIS DSP biquad Q31 vs F32
Hello,
I assembled an audio player based on a USB host based on STM32F4 (FLAC, WAV and later codecs), which is fed to the ES9018K2M DAC via I2S.
Currently I use Q31 biquads (arm_biquad_cas_df1_32x64_q31 and arm_biquad_cascade_df1_q31) for the 5-band equalizer, and I quickly run out of CPU time to do something else (the player strongly stutters when debugging is enabled).
The input data can be 16-24 bits stereo at 192K.
When I work in CMSIS DSP, I can not say,
1. What type of data should take less time on STM32F4 with built-in FPU, Q31 of F32?
2. Are there any advantages with regard to accuracy, S / N, THD, DNR, etc., using Q31 or F32?
hamid.abbaszadeh is offline   Reply With Quote
Old 05-25-2017, 09:38 AM   #2
Have you seen this app note from ST?
Old 06-05-2017, 02:50 PM   #3
hamid.abbaszadeh
So it seems F32 is very slightly faster than Q31 on FIR, looks promising so I will change the code for F32 and profile to see how much better it is in my application.
