Old 07-03-2017, 02:46 PM   #1
Default Atmega328 RX and TX uart Problems
I have a problem with my project.
I have Arduino sending 1 & 0 to the bluetooth module, which sends data to another module.
Well, my oscilloscope proves to me that I get the data on the 2nd module, but they could not read it.
I have a standalone atmega328 TQFP connected to the RX and TX pins of the second module, but it seems that Atmega328 does not recognize the data.
I connected RX & TX to PB0 and PD7, which are both PCINT outputs. They should be tied to PCINT contacts, which should do the trick to the right ???
Code:
#include<SoftwareSerial.h>
Softwareserial mySerial(7,8); // already tried to change them
void setup(){
mySerial.begin(115200); // everything is set to 115200
DDRB = 0x00000010;
void loop(){
if(mySerial.available()){
PORTB = 0b00000010;
Old 07-17-2017, 01:30 PM   #2
Clock source? Asynchronous serial (UART) depends on the baud rate of the receiver and transmitter to be within 5% or so. If one of the sides is using a low quality clock source (like internal RC oscillator) or if the clock frequency is not a nice multiple of the baud rate, then they can be too far off.
DS18B20 problems Raspberry Pi diksha.k Microcontrollers (MCU) 0 05-16-2017 06:16 PM
ATmega328 High Voltage Programming DRN_231 Microcontrollers (MCU) 1 05-16-2017 06:12 PM
UART Atmega128 is not working Anatoly Microcontrollers (MCU) 5 01-25-2016 09:13 AM
Questions about UART communication tracert Microcontrollers (MCU) 1 12-06-2015 06:07 PM
PIC32 and I2C EEPROM interface problems symbol Microcontrollers (MCU) 0 08-01-2015 11:12 AM
