Old 08-11-2017, 11:10 AM   #1
Default Discussion: Controller for automatic lighting of the working area in the kitchen. Part 1 - Arduino Version. Schematic, Sketch and PCB
General information In this article we will talk about a simple device that I designed for automatic control of additional LED lighting in the kitchen. Kitchen renovating and complete replacement of kitchen cabinetry are main reasons for development this device.
More: Controller for automatic lighting of the working area in the kitchen. Part 1 - Arduino Version. Schematic, Sketch and PCB
Old 08-11-2017, 11:10 AM   #2
Upon request, added a manual mode of turning the backlight on and off with the touch button. Touch Button Module TTP223B (common and cheap module for Arduino). The sketch is in the attachment below.
The module output is connected to the D4 Arduino port. The button operates as follows: when the sensor is touched, a high level appears at the module output. In standby mode, the output level is low and the module enters the energy-saving mode.
Principle of operation: touched the sensor - the brightness of the backlight gradually increases to 100% and the automatic mode of operation is turned off. They touched once again - the backlight turns off and the automatic mode algorithms are activated. If the backlight is turned on from the touch button, then in this mode it will work until it is turned off from the touch button.
Kitchen_Light_Controller_Arduino_TouchButton
Discussion: PCB Manufacturers List Radiolocman Robot Projects and Advices 1 03-26-2017 04:53 AM
Discussion: Intelligent Fan Controller. Part 3 - Software and controller configuration Radiolocman Robot Projects and Advices 1 10-10-2016 02:53 PM
Discussion: Robot shield for Arduino. Part 1 - Hardware and Schematic Radiolocman Robot Microcontrollers (MCU) 1 05-13-2014 05:17 PM
Discussion: Simple automatic kitchen sink light Radiolocman Robot Projects and Advices 1 09-19-2011 02:53 PM
Discussion: 255-Voice PCM Sound Generator. Part 1. Schematic Radiolocman Robot Microcontrollers (MCU) 1 07-25-2011 05:17 PM
