Old 08-29-2017, 03:59 PM   #1
Em_13
Em_13 is on a distinguished road
Default I Cooked my Arduino 3G module? SIM5320E
So I played with the SIM5320E, which is similar to the SIM900, but uses 3G. In short, I can short-circuit the antenna signal wire with 5V Arduino. Or a signal wire with GND. Or, maybe I accidentally connected 5V Arduino to the GND modules. I have no idea, but it immediately caused an unpleasant smell, but I did not see any visible smoke. The reason they were concerned was my mistake, I had an antenna tucked under some wires for convenience so that it would not just burst around in the wind. I use the arduino nano recorded on the back of the module, and when I moved it, either the antenna signal, or gnd, connected to 5V or gnd arduino.
Em_13 is offline   Reply With Quote
Old 10-03-2017, 07:37 PM   #2
A high res in focus picture might help. Also your nose might be able to identify
which end of module had over stressed part.
A magnifying glass exam of board might provide clues.
Discussion: Dual 13A μModule regulator with digital interface for remote monitoring & control of power Radiolocman Robot Projects and Advices 1 02-20-2016 08:47 PM
Discussion: One wire brings power & data to LCD module Radiolocman Robot Projects and Advices 1 04-19-2015 06:12 PM
Discussion: Serial four digit 7-segment LED display module Radiolocman Robot Projects and Advices 1 07-24-2012 11:53 AM
