Old 09-27-2017, 06:23 AM   #1
Default Discussion: Simply an adjustable low-pass filter
Bonnie Baker EDN A low-pass filter is the most common filter found in data acquisition systems. Typically this type of filter is used to reduce analog-to-digital converter (ADC) aliasing errors and noise outside the signal bandwidth.
More: Simply an adjustable low-pass filter
Old 09-27-2017, 06:23 AM   #2
As I understand, the "novelty" of the proposed solution is the use of a multiplexer, which allows one filter for several channels.
Sine adjustable low power Em_13 Projects and Advices 1 10-22-2016 09:18 AM
Atmega8 the digital filter Anatoly Microcontrollers (MCU) 1 11-12-2013 06:19 PM
