Old 10-23-2017, 04:59 PM   #1
mark
mark is on a distinguished road
Default ATMEGA328 running code but with excessive power usage
So, I could or maybe not put 12V on the atmega input pit for a few seconds and now the chip itself takes about 70 mA (I buzzed all IO leads to ground and power lines, so it seems just short) , while basically nothing is connected with the output terminals.
But otherwise it works fine, the code executes and outputs the correct data (it was a controller card for my ARM cluster). I assume that the chip is ruined (since even with the correct output it will probably prepare itself in a few minutes, but I'm curious what exactly can happen with an error inside the chip to cause a partial failure?
mark is offline   Reply With Quote
Old 10-31-2017, 08:55 PM   #2
Most likely ESD diodes, or something else in I/O ring.
Atmega328 RX and TX uart Problems rapid Microcontrollers (MCU) 1 07-17-2017 01:30 PM
ATmega328 High Voltage Programming DRN_231 Microcontrollers (MCU) 1 05-16-2017 06:12 PM
PWM code help for full bridge PIC18F4550 xC8 usama14 Microcontrollers (MCU) 1 02-17-2016 06:01 PM
Controller is not running properly as per logic after removing PICKIT3 programmer Anatoly Microcontrollers (MCU) 1 07-27-2015 12:29 PM
Servo motor Arduino code tracert Microcontrollers (MCU) 2 07-11-2015 09:56 AM
