Old 07-25-2011, 05:17 PM   #1
Default Discussion: 255-Voice PCM Sound Generator. Part 1. Schematic
This is a simple sound generator based on 8-pin SD Audio Player. It is built with an Atmel ATtiny861 microcontroller from Atmel and an SD memory card.
More: 255-Voice PCM Sound Generator. Part 1. Schematic
Old 07-25-2011, 05:17 PM   #2
pschimpf
pschimpf is on a distinguished road
Thanks so much for sharing this. It is perfect for a project I am working on. I have three questions for you: (a) Your mono (OCL) configuration implies that the output signal is differential in that case. Is that true? (b) If so, any particular reason I should not prefer that with an Amp as opposed to the Mono (Hi Res w/ Amp), which appears to mix two single-ended signals prior to amplification? (c) Can you suggest a simple (couple of Watts or so) Amp design? Since the signals are PWM I'm thinking just a couple of FETs to boost current might be sufficient (i.e. the output stage of a class D amplifier)?
pschimpf is offline   Reply With Quote
Discussion: 255-Voice PCM Sound Generator. Part 2. Software Radiolocman Robot Microcontrollers (MCU) 2 04-27-2011 08:05 PM
Discussion: Small fully featured ATXMEGA32 scope. Part 1. Schematic Radiolocman Robot Microcontrollers (MCU) 1 01-11-2011 03:03 PM
