Dual Cortex-M4F MCU offers exceptional performance for smart meters and other sensing applications
Toshiba Electronics Europe (TEE) has introduced a new addition to its TX04 series of ARM Cortex-M4F core-based microcontrollers (MCUs). The TMPM411F20XBG MCU facilitates electric power calculation and communication in smart meters, as well as sensing and communications in other measurement devices.
A typical smart meter comprises separate controllers for electric power calculation, data communication, and output display. By integrating multiple function alities, the TMPM411F20XBG achieves independent control of the electric power calculation and communication control in a single chip, reducing the circuit board area within the smart meter.
Property | Value | Unit |
Group name | M410 | |
Number of bits | 32 | bit |
ROM size | 2048 | Kbyte |
ROM type | Flash | |
RAM size | 290 | Kbyte |
DMA controllers | 34 | ch |
DMA controllers units | 2 | units |
UART/SIO | 6 | ch |
Full UART | 2 | ch |
I2C | 1 | ch |
A/D converters(12bit) | 9 | ch |
Number of A/D converter (12bit) units | 2 | units |
Timer (16bit) | 5 | ch |
Watchdog timer | Available | |
Number of External interrupt pins | 13 | pins |
RTC | 1 | ch |
Clock gear function | Available | |
Trace function | Available | |
On-chip debug function | Available | |
JTAG (Boundary-Scan) | Available | |
Number of I/O ports | 93 | port |
Drivers(LCD)(Segment x Common) | 32 × 4 |
The TMPM411F20XBG implements tamper detection and failure detection with very low power consumption, and also incorporates key security functions suitable for secure network communication. These include Advanced Encryption Standard (AES), Secure Hash Algorithm (SHA) and Entropy Source Generator (ESG). Its large on-chip Flash memory allows for robust code and data storage as required for extensive service lifetime.
The TMPM411F20XBG operates at 2.7 to 3.6V, with a maximum operating frequency of 80MHz. It has an internal memory of 2048 Kbytes Flash and 290 Kbytes total SRAM, 34-channel direct memory access (DMA), 9-channel 12-bit analog-to-digital converter (ADC).
The product is available in 14×14 mm VFGBA193 package.
