Circuits & Schematics
Search results: 2,244 Output: 1-10
  1. Ashutosh Sapre
    A recent Design Idea (DI), “Silly simple precision 0/20 mA to 4/20 mA converter,” ( Ref. 1 ) by prolific DI contributor Stephen Woodward uses the venerable LM337 regulator in a creative configuration along with a few passive components, ...
    Feb 13, 2026
  2. Hesam Moshiri
    Whenever you hear the transformerless supply term, you initially imagine the capacitor-based solution: a high-voltage non-polarized capacitor in series with the mains line, a bridge rectifier, a Zener diode, and a filtering electrolytic capacitor. ...
    Feb 12, 2026
  1. Paul C Florian
    Commercially available IR distance rangers typically handle a 3- to 30-in. detection distance. Many times, it is necessary to determine smaller distances. The circuit in Figure 1 is useful for measuring small distances to reflective surfaces. Its ...
    Feb 11, 2026
  2. Stephen Woodward
    An important figure of merit for all precision constant current sources is their active impedance. Which is to say, just how “constant” is their output held against changes in applied voltage? Frequent and expert Design Idea (DI) ...
    Feb 5, 2026
  3. Jayapal Ramalingam
    Industrial systems normally use both analog and digital circuits. While digital circuits include microcontrollers that operate at 5 VDC, analog circuits operate generally at either 12 or 15 VDC. In some systems, it may be necessary to switch on ...
    Feb 4, 2026
  4. Peter Demchenko
    Large power supplies that operate from ac wall voltage have large input-filter capacitors. You must limit the inrush current to those capacitors. Otherwise, the supply may trip the ac circuit breaker, or you may damage the rectifier, filer chokes, ...
    Jan 30, 2026
  5. Jaime Castelló José María Espí Marcos Arasa Rafael García-Gil
    The circuit in this Design Idea detects short-circuit faults or excess-current conditions in line-operated equipment, such as a UPS (uninterruptible power supply), across an isolation boundary. If the load current rises higher than a predetermined ...
    Jan 30, 2026
  6. Stephen Woodward
    A few months back, frequent DI contributor Nick Cornford showed us some clever circuits using the TDA7052A audio amplifier as a power oscillator. His designs also demonstrate the utility of the 7052’s nifty DC antilog gain control input: ...
    Jan 30, 2026
  7. Stephen Woodward
    The versatility of the venerable LMC555 CMOS analog timer is so well known it’s virtually a cliche, but sometimes it can still surprise us. The circuit in Figure 1 is an example. In it a single linear pot in a simple RC network sets the ...
    Jan 29, 2026
  8. David A. Johnson
    This circuit acts as an AC/DC relay with a rating up to 50 volts peak and up to 10 Amps of current. The differential oscillator supplies voltage to the gates of the two FETs with good isolation will drawing only 1.5 mA of current. Materials on the ...
    Jan 22, 2026
