Datasheet LMC7101 (Microchip) - 3
ManufacturerMicrochip
DescriptionLMC7101 is a 500kHz gain bandwidth amplifier designed to operate from 2.7V to 12V single-ended power supplies with guaranteed performance at supply voltages of 2.7V, 3V, 5V, and 12V
Pages / Page12 / 3 — LMC7101A. LMC7101B. Symbol. Parameter. Condition. Typ. Min. Max. Units. …
File Format / SizePDF / 132 Kb
LMC7101A. LMC7101B. Symbol. Parameter. Condition. Typ. Min. Max. Units. Note 6. 0.95. Electrical Characteristics—DC (5V). bold. 0.00. 5.00. 4.85. 0.15
LMC7101A LMC7101B Symbol Parameter Condition Typ Min Max Units Note 6 0.95 Electrical Characteristics—DC (5V) bold 0.00 5.00 4.85 0.15
LMC7101 Micrel, Inc.
LMC7101A LMC7101B Symbol Parameter Condition Typ Min Max Min Max Units
CMRR Common-Mode Rejection Ratio 0V ≤ V CM ≤ 3.0V,
Note 6
74 60 60 dB V Input Common-Mode Voltage input low, CMRR CM ≥ 50dB –0.3 0 0 V input high, CMRR ≥ 50dB 3.3 3.0 3.0 V PSRR Power Supply Rejection Ratio V+ = 1.5V to 6.0V, V– = 80 68 60 dB –1.5V to –6.0V, V = 0 CM C Common-Mode Input Capacitance 3 pF IN V Output Swing output high, R = 2k 2.992 2.9 2.9 V OUT L output low, R = 2k 0.008 0.1 0.1 V L output high, R = 600 L Ω 2.973 2.85 2.85 V output low, R = 600 L Ω 0.027 0.15 0.15 V I Supply Current 0.5 0.81 0.81 mA S
0.95 0.95
mA
V+ = +5.0V, V– = 0V, V = 1.5V, V = V+/2; R = 1M = 25 CM OUT L Ω; TJ °C,
bold
values indicate –40°C ≤ TJ ≤ +85°C; unless noted
V Input Offset Voltage 0.11 3 7 mV OS
5 9
mV TCV Input Offset Voltage Average Drift 1.0 OS µV/°C I Input Bias Current 1.0
64 64
pA B I Input Offset Current 0.5
32 32
pA OS R Input Resistance >1 T IN Ω CMRR Common-Mode Rejection Ratio 0V ≤ V CM ≤ 5V,
Note 6
82 60 60 dB
55 55
dB V Input Common-Mode Voltage input low, CMRR CM ≥ 50dB –0.3 –0.20 –0.20 V
0.00 0.00
V input high, CMRR ≥ 50dB 5.3 5.20 5.20 V
5.00 5.00
V +PSRR Positive Power Supply V+ = 5V to 12V, 82 70 65 dB Rejection Ratio V– = 0V, V = 1.5V
65 62
dB OUT –PSRR Negative Power Supply V+ = 0V, V– = –5V to –12V, 82 70 65 dB Rejection Ratio V = –1.5V
65 62
dB OUT C Common-Mode Input Capacitance 3 pF IN V Output Swing output high, R = 2k 4.989 4.9 4.9 V OUT L
4.85 4.85
V output low, R = 2k 0.011 0.1 0.1 V L
0.15 0.15
V output high, R = 600 L Ω 4.963 4.9 4.9 V
4.8 4.8
V output low, R = 600 L Ω 0.037 0.1 0.1 V
0.2 0.2
V I Output Short Circuit Current sourcing (V = 0V) or 200 120 120 mA SC OUT
Note 7
sinking (V = 5V)
80 80
mA OUT I Supply Current V = V+/2 0.5 0.85 0.85 mA S OUT
1.0 1.0
mA February 2005 3 LMC7101
