Datasheet AD8091, AD8092 (Analog Devices) - 6
DescriptionLow Cost, High Speed Rail-to-Rail Amplifiers
Pages / Page20 / 6 — AD8091/AD8092. ABSOLUTE MAXIMUM RATINGS. Table 4. Parameter Rating. ESD …
RevisionC
File Format / SizePDF / 323 Kb
AD8091/AD8092. ABSOLUTE MAXIMUM RATINGS. Table 4. Parameter Rating. ESD CAUTION
AD8091/AD8092 ABSOLUTE MAXIMUM RATINGS Table 4 Parameter Rating ESD CAUTION
link to page 7 link to page 7
AD8091/AD8092 ABSOLUTE MAXIMUM RATINGS Table 4.
Stresses above those listed under Absolute Maximum Ratings
Parameter Rating
may cause permanent damage to the device. This is a stress Supply Voltage 12.6 V rating only; functional operation of the device at these or any Power Dissipation See Figure 4 other conditions above those indicated in the operational Common-Mode Input Voltage ±V section of this specification is not implied. Exposure to absolute S Differential Input Voltage ±2.5 V maximum rating conditions for extended periods may affect Output Short-Circuit Duration See Figure 4 device reliability. Storage Temperature Range −65°C to +125°C
ESD CAUTION
Operating Temperature Range −40°C to +85°C Lead Temperature (Soldering 10 sec) 300°C Rev. C | Page 6 of 20 Document Outline FEATURES APPLICATIONS CONNECTION DIAGRAMS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION MAXIMUM POWER DISSIPATION TYPICAL PERFORMANCE CHARACTERISTICS LAYOUT, GROUNDING, AND BYPASSING CONSIDERATIONS POWER SUPPLY BYPASSING GROUNDING INPUT CAPACITANCE INPUT-TO-OUTPUT COUPLING DRIVING CAPACITIVE LOADS OVERDRIVE RECOVERY ACTIVE FILTERS SYNC STRIPPER SINGLE-SUPPLY COMPOSITE VIDEO LINE DRIVER OUTLINE DIMENSIONS ORDERING GUIDE
