13 /8 — OP290. 140. TA = 25°C. VS = ±15V. NEGATIVE SUPPLY. G = 100. 120. (d N. dB …
Revision
C
PDF / 268 Kb
OP290. 140. TA = 25°C. VS = ±15V. NEGATIVE SUPPLY. G = 100. 120. (d N. dB (. IO T. EC 100. G = 10. POSITIVE SUPPLY. Y R. -LOOP D. PPL. LOS. G = 1. –20. 100
OP29060140TA = 25°CTA = 25°CVS = ±15V)NEGATIVE SUPPLYBG = 100120)40(d NdB (IO TINEC 100GAG = 10EJPOSITIVE SUPPLY20Y R-LOOP DPPL80ESULOSG = 1CER0W60PO–2040101001k10k100k 009 1101001k 012 FREQUENCY (Hz)FREQUENCY (Hz) 00327- 00327- Figure 9. Closed-Loop Gain vs. Frequency Figure 12. Power Supply Rejection vs. Frequency 6140TA = 25°CTA = 25°CV+ = 5VVS = ±15V5V– = 0V)B)V120dG (N (4IOWINCTS100JEGE3RE DEOLTAO80MT V U2N- OTPM MOU601CO0401001k10k100k 010 1101001k 013 LOAD RESISTANCE (Ω)FREQUENCY (Hz) 00327- 00327- Figure 10. Output Voltage Swing vs. Load Resistance Figure 13. Common-Mode Rejection vs. Frequency 16T1kA = 25°CTVA = 25°C14S = ±15VVS = ±15V)z)V12HG (V/WIN10Y (nST SIGE8EN100E DOLTAG6AT VTULTP4OUISE VO O2N01001k10k100k10 011 0.11101001k 014 LOAD RESISTANCE (Ω) 00327- FREQUENCY (Hz) 00327- Figure 11. Output Voltage Swing vs. Load Resistance Figure 14. Noise Voltage Density vs. Frequency Rev. C | Page 7 of 12 Document Outline Features Pin Connections General Description Revision History Specifications Electrical Characteristics Absolute Maximum Ratings ESD Caution Typical Performance Characteristics Theory of Operation Battery-Powered Applications Input Voltage Protection Single-Supply Output Voltage Range Applications Information Temperature to 4 mA to 20 mA Transmitter Variable Slew Rate Filter Low Overhead Voltage Reference Outline Dimensions Ordering Guide
