Datasheet LTC2188 (Analog Devices) - 7
Description16-Bit, 20Msps Low Power Dual ADC
Pages / Page36 / 7 — power requireMenTs. The. denotes the specifications which apply over the …
File Format / SizePDF / 622 Kb
power requireMenTs. The. denotes the specifications which apply over the full operating temperature
power requireMenTs The denotes the specifications which apply over the full operating temperature
LTC2188
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Note 9) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS CMOS Output Modes: Full Data Rate and Double Data Rate
VDD Analog Supply Voltage (Note 10) l 1.7 1.8 1.9 V OVDD Output Supply Voltage (Note 10) l 1.1 1.8 1.9 V IVDD Analog Supply Current DC Input l 42 50 mA Sine Wave Input 43 mA IOVDD Digital Supply Current Sine Wave Input, OVDD = 1.2V 1.6 mA PDISS Power Dissipation DC Input l 75.6 90 mW Sine Wave Input, OVDD = 1.2V 79.3 mW
LVDS Output Mode
VDD Analog Supply Voltage (Note 10) l 1.7 1.8 1.9 V OVDD Output Supply Voltage (Note 10) l 1.7 1.8 1.9 V IVDD Analog Supply Current Sine Input, 1.75mA Mode 45 mA Sine Input, 3.5mA Mode l 47 54 mA IOVDD Digital Supply Current Sine Input, 1.75mA Mode 38 mA (0VDD = 1.8V) Sine Input, 3.5mA Mode l 74 83 mA PDISS Power Dissipation Sine Input, 1.75mA Mode 149 mW Sine Input, 3.5mA Mode l 218 247 mW
All Output Modes
PSLEEP Sleep Mode Power 1 mW PNAP Nap Mode Power 10 mW PDIFFCLK Power Increase with Differential Encode Mode Enabled 20 mW (No increase for Nap or Sleep Modes)
TiMing characTerisTics The
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Note 5) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
fS Sampling Frequency (Note 10) l 1 20 MHz tL ENC Low Time (Note 8) Duty Cycle Stabilizer Off l 20 25 500 ns Duty Cycle Stabilizer On l 2 25 500 ns tH ENC High Time (Note 8) Duty Cycle Stabilizer Off l 20 25 500 ns Duty Cycle Stabilizer On l 2 25 500 ns tAP Sample-and-Hold Acquisition Delay Time 0 ns
SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Digital Data Outputs (CMOS Modes: Full Data Rate and Double Data Rate)
tD ENC to Data Delay CL = 5pF (Note 8) l 1.1 1.7 3.1 ns tC ENC to CLKOUT Delay CL = 5pF (Note 8) l 1 1.4 2.6 ns tSKEW DATA to CLKOUT Skew tD – tC (Note 8) l 0 0.3 0.6 ns Pipeline Latency Full Data Rate Mode 6 Cycles Double Data Rate Mode 6.5 Cycles 2188f 7 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configurations Order Information Converter Characteristics Analog Input Dynamic Accuracy Internal Reference Characteristics Digital Inputs and Outputs Power Requirements Timing Characteristics Timing Diagrams Typical Performance Characteristics Pin Functions Functional Block Diagram Applications Information Typical Applications Package Description Typical Application Related Parts
