Datasheet LTC2392-16 (Analog Devices) - 26
Description | 16-Bit, 500ksps SAR ADC with 94dB SNR |
Pages / Page | 26 / 26 — typical application. ADC Driver: Single-Ended Input to Differential … |
File Format / Size | PDF / 321 Kb |
typical application. ADC Driver: Single-Ended Input to Differential Output. relateD parts. PART NUMBER. DESCRIPTION. COMMENTS. DACs
LTC2392-16
typical application ADC Driver: Single-Ended Input to Differential Output
5V 0.1µF 249Ω VIN + 5V 0V to 4V – +IN1 SHDN V+ OUT2 + – – AIN LT6350 – 2200pF LTC2392-16 + A + IN –IN1 +IN2 V– OUT1 239216 TA03 249Ω 0.1µF 0.1µF 499Ω 2V –5V
relateD parts PART NUMBER DESCRIPTION COMMENTS
LTC1411 14-Bit 2.5Msps Parallel ADC 5V Supply, 1-Channel, 80dB SNR, ±1.8V, ±1.27V, ±0.9V, ±0.64V Input Ranges, SSOP-36 Package LTC1609 16-Bit 200ksps Serial ADC 5V Supply, 1-Channel, 87dB SNR, Resistor-Selectable Inputs: ±10V, ±5V, ±3.3V, 0V to 4V, 0V to 5V, 0V to 10V LTC1864 16-Bit 250ksps Serial ADC 5V Supply, 1-Channel, 4.3mW, MSOP-8 Package LTC1864L 16-Bit 150ksps Serial ADC 3V Supply, 1-Channel, 1.3mW, MSOP-8 Package LTC1865 16-Bit 250ksps Serial ADC 5V Supply, 2-Channel, 4.3mW, MSOP-8 Package LTC1865L 16-Bit 150ksps Serial ADC 3V Supply, 2-Channel, 1.3mW, MSOP-8 Package LTC1867 16-Bit, 200ksps 8-Channel ADC 5V Supply, 6.5mW, SSOP-16 Package, Pin Compatible with LTC1863, LTC1867L LTC2355-14/LTC2356-14 14-Bit, 3.5Msps Serial ADCs 3.3V Supply, 1-Channel, 18mW, MSOP-10 Package LTC2391-16 16-Bit, 250ksps Parallel/Serial ADC 5V Supply, Differential Input, 94dB SNR, ±4.096V Input Range, Pin Compatible with the LTC2393-16, LTC2392-16 LTC2393-16 16-Bit, 1Msps Parallel/Serial ADC 5V Supply, Differential Input, 94dB SNR, ±4.096V Input Range, Pin Compatible with the LTC2392-16, LTC2391-16
DACs
LTC2641 16-Bit Single Serial VOUT DACs ±1LSB INL, ±1LSB DNL, MSOP-8 Package, 0V to 5V Output LTC2630 12-/10-/8-Bit Single VOUT DACs SC70 6-Pin Package, Internal Reference, ±1LSB INL (12 Bits)
References
LT1236 Precision Reference in SO-8 Package 5V, 10V; 0.05% Initial Accuracy (Max); 5ppm Tempco (Max) LTC6655 0.25ppmP-P Noise, Low Drift Precision Reference 0.025% Initial Accuracy (Max), 2ppm Tempco (Max), 0.25ppmP-P Noise (0.1Hz to 10Hz) in MSOP-8 Package
Amplifiers
LT1469 Dual 90MHz, 22V/µs Dual Op Amps in 4mm × 4mm 125µV (Max) Input Offset Voltage, Low Distortion: –96.5dB at DFN-12 Package 100kHz, 10VP-P , Settling Time: 900ns LT1806/LT1807 325MHz, Single/Dual Precision Op Amps in TSOT23-6, Rail-to-Rail Input and Output, Low Distortion, –80dBc at 5MHz, MSOP-8 Packages Low Voltage Noise: 3.5nV/√Hz LTC6200/LTC6200-5/ 165MHz/800MHz/1.6GHz Op Amps with Low Noise Voltage: 0.95nV/√Hz (100kHz), Low Distortion: LTC6200-10 Unity Gain/AV = 5/AV = 10 –80dB at 1MHz, TSOT23-6 Package LT6350 Low Noise Single-Ended-to-Differential ADC Driver Rail-to-Rail Input and Outputs, 240ns 0.01% Settling Time 239216fa 26 Linear Technology Corporation LT 0712 REV A • PRINTED IN USA 1630 McCarthy Blvd., Milpitas, CA 95035-7417 (408) 432-1900 ● FAX: (408) 434-0507 ● www.linear.com LINEAR TECHNOLOGY CORPORATION 2010 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Analog Input Converter Characteristics Dynamic Accuracy Internal Reference Characteristics Digital Inputs and Digital Outputs Power Requirements Timing Characteristics Typical Performance Characteristics Pin Functions Functional Block Diagram Timing Diagrams Applications Information Package Description Revision History Typical Application Related Parts
