Datasheet LT3013 (Analog Devices)
Description250mA, 4V to 80V Low Dropout Micropower Linear Regulator with PWRGD
Pages / Page20 / 1 — FEATURES. DESCRIPTION. Wide Input Voltage Range: 4V to 80V. Low Quiescent …
File Format / SizePDF / 233 Kb
FEATURES. DESCRIPTION. Wide Input Voltage Range: 4V to 80V. Low Quiescent Current: 65μA. Low Dropout Voltage: 400mV
Datasheet LT3013 Analog Devices
LT3013 250mA, 4V to 80V Low Dropout Micropower Linear Regulator with PWRGD
FEATURES DESCRIPTION
n
The LT®3013 is a high voltage, micropower low dropout n
linear regulator. The device is capable of supplying 250mA n
of output current with a dropout voltage of 400mV. Designed n
Output Current: 250mA
for use in battery-powered or high voltage systems, the low n No Protection Diodes Needed quiescent current (65μA operating and 1μA in shutdown) n Adjustable Output from 1.24V to 60V makes the LT3013 an ideal choice. Quiescent current is n 1μA Quiescent Current in Shutdown also well controlled in dropout. n Stable with 3.3μF Output Capacitor Other features of the LT3013 include a PWRGD fl ag to n Stable with Aluminum, Tantalum or Ceramic indicate output regulation. The delay between regulated Capacitors output level and fl ag indication is programmable with n Reverse-Battery Protection a single capacitor. The LT3013 also has the ability to n No Reverse Current Flow from Output to Input operate with very small output capacitors. The regulator n Thermal Limiting is stable with only 3.3μF on the output while most older n Thermally Enhanced 16-Lead TSSOP and devices require between 10μF and 100μF for stability. 12-Pin (4mm × 3mm) DFN Package Small ceramic capacitors can be used without any need for series resistance (ESR) as is common with other
regulators. Internal protection circuitry includes reverse- battery protection, current limiting, thermal limiting and n Low Current High Voltage Regulators reverse current protection. n Regulator for Battery-Powered Systems n Telecom Applications The device is available with an adjustable output with a n Automotive Applications 1.24V reference voltage. The LT3013 regulator is available in the thermally enhanced 16-lead TSSOP and the low profi le (0.75mm), 12-pin (4mm × 3mm) DFN package, both providing excellent thermal characteristics. , LT, LTC and LTM are registered trademarks of Linear Technology Corporation. All other trademarks are the property of their respective owners.
TYPICAL APPLICATION Dropout Voltage
400
5V Supply with Shutdown
350 300 VOUT IN OUT 5V GE (mV) 250 V TA IN 250mA LT3013 750k 5.4V TO 200 1μF 1.6M 3.3μF SHDN 80V ADJ PWRGD 150 249k GND CT DROPOUT VOL 100 3013 TA01
VSHDN OUTPUT
1000pF 50 <0.3V OFF >2.0V ON 0 0 50 100 150 200 250 OUTPUT CURRENT (mA) 3013 TA02 3013fe 1
