Datasheet LTC1735-1 (Analog Devices) - 28
Description | High Efficiency Synchronous Step-Down Switching Regulator |
Pages / Page | 28 / 28 — TYPICAL APPLICATIO. High Efficiency Dynamic Output Voltage Selectable CPU … |
File Format / Size | PDF / 356 Kb |
TYPICAL APPLICATIO. High Efficiency Dynamic Output Voltage Selectable CPU Power Supply for SpeedStep Enabled Processors
LTC1735-1
U TYPICAL APPLICATIO High Efficiency Dynamic Output Voltage Selectable CPU Power Supply for SpeedStep Enabled Processors
PGOOD RUN VIN 4.5V TO 24V R7 JP1 100k LATCH-OFF R6 R8 INTV DISABLE 680k 4.7Ω CC CIN C 22µF F1 CIN: MARCON THCR70E1H226ZT 0.1 50V µF COUT: PANASONIC EEFVE06181R C CERAMIC OSC 47pF 1 16 Q1 L1: PANASONIC ETQP6F1R2HFA COSC TG ×2 FDS6680A RSENSE: IRC CRF2512-01-R004F CSS 0.1µF 2 15 RUN/SS BOOST L1 C R C R C2 330pF C1 33k 3 14 B 0.22µF SENSE I 1.2µH TH LTC1735-1 SW 0.004Ω VOUT CC1 47pF 4 13 D1 1.35V OR 1.60V PGOOD VIN CMDSH-3 12A 5 12 D2 R1 SENSE – INTVCC C1 C2 MBRS340T3 10k C + S1 6 11 C2 C4 C 47pF SENSE + BG 47pF Q2, Q3 0.5% OUT 1000pF 4.7µF 1µF + 180µF 7 10 FDS6680A V R3 4V OSENSE PGND C3 ×2 8 9 33.2k SP 5V 47pF SGND EXTVCC 1% ×4 INPUT (OPTIONAL) Q4 2N7002 VSEL = 1: VOUT = 1.60V R5 10Ω R2 VSEL = 0: VOUT = 1.35V 14.3k R4 10Ω 0.5% GND 1735-1 TA01
RELATED PARTS PART NUMBER DESCRIPTION COMMENTS
LTC1149 High Efficiency Synchronous Step-Down Controller 100% DC, Std Threshold MOSFETs, VIN < 48V LTC1159 High Efficiency Synchronous Step-Down Controller 100% DC, Logic Level MOSFETs, VIN < 40V LT1375/LT1376 1.5A 500kHz Step-Down Switching Regulator High Efficiency LTC1435A High Efficiency Low Noise Synchronous Step-Down Controller, N-Ch Drive Burst Mode Operation, 16-Pin Narrow SO LTC1436A/LTC1436A-PLL High Efficiency Low Noise Synchronous Step-Down Converter, N-Ch Drive Adaptive PowerTM Mode 20-Pin, 24-Pin SSOP LTC1474/LTC1475 Ultralow Quiescent Current Step-Down Monolithic Switching Regulator 100% DC, 8-Pin MSOP, IQ = 10µA LTC1628 Dual High Efficiency 2-Phase Step-Down Controller Antiphase Drive, 28-Pin SSOP, 3.5V ≤ VIN ≤ 36V LTC1702 550kHz Dual Output Synchronous Step-Down Controller Antiphase Drive, 24-Pin SSOP, VIN ≤ 7V LTC1709 PolyPhaseTM Synchronous Controller with 5-Bit VID Up to 42A, Minimum Input Capacitors, 1.3V ≤ VOUT ≤ 3.5V LTC1735 High Efficiency Synchronous Step-Down Contoller, N-Channel Drive Burst Mode Opertion, 16-Pin Narrow SSOP LTC1736 High Efficiency Synchronous Step-Down Controller with 5-Bit VID Control Output Fault Protection, 24-Pin SSOP LTC1772 SOT-23 High Efficiency Constant Frequency Step-Down Controller 100% DC, 550kHz, SOT-23, Current Mode Adaptive Power and PolyPhase are trademarks of Linear Technology Corporation. sn17351 17351fs LT/TP 0100 4K • PRINTED IN USA 28 Linear Technology Corporation 1630 McCarthy Blvd., Milpitas, CA 95035-7417 (408) 432-1900 ● FAX: (408) 434-0507 ● www.linear-tech.com LINEAR TECHNOLOGY CORPORATION 1999
