Datasheet LTC3862 (Linear Technology)
ManufacturerLinear Technology
DescriptionMulti-Phase Current Mode Step-Up DC/DC Controller
Pages / Page42 / 1 — FeaTures. DescripTion. Wide VIN Range: 4V to 36V Operation. 2-Phase …
RevisionC
FeaTures. DescripTion. Wide VIN Range: 4V to 36V Operation. 2-Phase Operation Reduces Input and Output. Capacitance
Datasheet LTC3862 Linear Technology, Revision: C
LTC3862 Multi-Phase Current Mode Step-Up DC/DC Controller
FeaTures DescripTion
n
The LTC®3862 is a two phase constant frequency, current n
mode boost and SEPIC controller that drives N-channel
Capacitance
power MOSFETs. Two phase operation reduces system n
Fixed Frequency, Peak Current Mode Control
filtering capacitance and inductance requirements. n
5V Gate Drive for Logic-Level MOSFETs
The operating frequency can be set with an external resistor n
Adjustable Slope Compensation Gain
over a 75kHz to 500kHz range and can be synchronized n
Adjustable Max Duty Cycle (Up to 96%)
to an external clock using the internal PLL. Multi-phase n
Adjustable Leading Edge Blanking
operation is possible using the SYNC input, the CLKOUT n ±1% Internal Voltage Reference output and the PHASEMODE control pin allowing 2-, 3-, n Programmable Operating Frequency with One 4-, 6- or 12-phase operation. External Resistor (75kHz to 500kHz) n Phase-Lockable Fixed Frequency 50kHz to 650kHz Other features include an internal 5V LDO with undervoltage n SYNC Input and CLKOUT for 2-, 3-, 4-, 6- or lockout protection for the gate drivers, a precision RUN 12-Phase Operation (PHASEMODE Programmable) pin threshold with programmable hysteresis, soft-start n Internal 5V LDO Regulator and programmable leading edge blanking and maximum n 24-Lead Narrow SSOP Package duty cycle. n 5mm × 5mm QFN with 0.65mm Lead Pitch and
PART NUMBER INTV
24-Lead Thermally Enhanced TSSOP Packages
CC VIN ON VIN OFF
LTC3862 5V 3.3V 2.9V
applicaTions
LTC3862-1 10V 7.5V 7.0V LTC3862-2 10V 4.4V 3.9V n Automotive, Telecom and Industrial Power Supplies L, LT, LTC, LTM, Linear Technology and the Linear logo are registered trademarks of Linear Technology Corporation. All other trademarks are the property of their respective owners. Protected by U.S. Patents, including 6144194, 6498466, 6611131.
Typical applicaTion
VIN 5V TO 36V 22µF 84.5k 19.4µH 19.4µH 50V VOUT 24.9k V 48V
Efficiency vs Output Current
IN RUN GATE1 5A (MAX) 98 INTV V CC SENSE1+ OUT = 48V 220µF 96 V 4.7µF IN = 12V LTC3862 0.006Ω 50V 94 66.5k BLANK SENSE1– FREQ 92 GATE2 10nF 10k SYNC SENSE2+ 90 PLLFLTR VIN = 24V 10nF 0.006Ω 88 VIN = 5V SS EFFICIENCY (%) 86 1nF SENSE2– 3V8 PGND 84 CLKOUT FB SLOPE 82 10nF DMAX ITH PHASEMODE 80100 1000 10000 475k 12.4k 68.1k SGND 100pF LOAD CURRENT (mA) 3862 TA01b 3862 TA01 3862fc For more information www.linear.com/LTC3862 1 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Functional Diagram Operation Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
