Datasheet AD9681 (Analog Devices) - 2
DescriptionOctal, 14-Bit, 125 MSPS, Serial LVDS, 1.8 V Analog-to-Digital Converter
Pages / Page41 / 2 — AD9681* PRODUCT PAGE QUICK LINKS Last Content Update: 06/09/2017. …
RevisionC
AD9681* PRODUCT PAGE QUICK LINKS Last Content Update: 06/09/2017. COMPARABLE PARTS. DESIGN RESOURCES. EVALUATION KITS
AD9681* PRODUCT PAGE QUICK LINKS Last Content Update: 06/09/2017 COMPARABLE PARTS DESIGN RESOURCES EVALUATION KITS
View a parametric search of comparable parts. • AD9681 Material Declaration • PCN-PDN Information
EVALUATION KITS
• Quality And Reliability • AD9681 Evaluation Board • Symbols and Footprints
DOCUMENTATION DISCUSSIONS Data Sheet
View all AD9681 EngineerZone Discussions. • AD9681: Octal, 14-Bit, 125 MSPS, Serial LVDS, 1.8 V Analog-to-Digital Converter Data Sheet
SAMPLE AND BUY User Guides
Visit the product page to see pricing options. • Evaluating the AD9681 Analog-to-Digital Converter
TECHNICAL SUPPORT TOOLS AND SIMULATIONS
Submit a technical question or find your regional support • AD9681 ADISimADC model number. • AD9681 Input Impedance
DOCUMENT FEEDBACK REFERENCE MATERIALS
Submit feedback for this data sheet.
Press
• Low-Power 14-bit A/D Converters Enable High- Performance, Multi-Channel Data Acquisition in Compact Package
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION SIMPLIFIED FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY FUNCTIONAL BLOCK DIAGRAM SPECIFICATIONS DC SPECIFICATIONS AC SPECIFICATIONS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS TIMING SPECIFICATIONS Timing Diagrams ABSOLUTE MAXIMUM RATINGS THERMAL CHARACTERISTICS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS EQUIVALENT CIRCUITS THEORY OF OPERATION ANALOG INPUT CONSIDERATIONS Input Common Mode Differential Input Configurations VOLTAGE REFERENCE Internal Reference Connection External Reference Operation CLOCK INPUT CONSIDERATIONS Clock Input Options Input Clock Divider Clock Duty Cycle Jitter Considerations POWER DISSIPATION AND POWER-DOWN MODE DIGITAL OUTPUTS AND TIMING SDIO/OLM Pin SCLK/DTP Pin CSB1 and CSB2 Pins RBIAS1 and RBIAS2 Pins OUTPUT TEST MODES SERIAL PORT INTERFACE (SPI) CONFIGURATION USING THE SPI HARDWARE INTERFACE CONFIGURATION WITHOUT THE SPI SPI ACCESSIBLE FEATURES MEMORY MAP READING THE MEMORY MAP REGISTER TABLE Open Locations Default Values Logic Levels Channel Specific Registers MEMORY MAP MEMORY MAP REGISTER DESCRIPTIONS Device Index (Register 0x05) Transfer (Register 0xFF) Power Modes (Register 0x08) Enhancement Control (Register 0x0C) Output Mode (Register 0x14) Output Adjust (Register 0x15) Output Phase (Register 0x16) Serial Output Data Control (Register 0x21) Resolution/Sample Rate Override (Register 0x100) User I/O Control 2 (Register 0x101) User I/O Control 3 (Register 0x102) APPLICATIONS INFORMATION DESIGN GUIDELINES POWER AND GROUND RECOMMENDATIONS BOARD LAYOUT CONSIDERATIONS Sources of Coupling Crosstalk Between Inputs Coupling of Digital Output Switching Noise to Analog Inputs and Clock CLOCK STABILITY CONSIDERATIONS VCM REFERENCE DECOUPLING SPI PORT OUTLINE DIMENSIONS ORDERING GUIDE
