Datasheet AD7191 (Analog Devices) - 8
DescriptionPin-Programmable, Ultralow Noise, 24-Bit, Sigma-Delta ADC for Bridge Sensors
Pages / Page21 / 8 — AD7191. ABSOLUTE MAXIMUM RATINGS. Table 3. Parameter. Rating. ESD CAUTION
RevisionA
File Format / SizePDF / 332 Kb
AD7191 ABSOLUTE MAXIMUM RATINGS Table 3 Parameter Rating ESD CAUTION
TA = 25°C, unless otherwise noted.
Table 3.
Stresses above those listed under Absolute Maximum Ratings
Parameter Rating
may cause permanent damage to the device. This is a stress AV rating only; functional operation of the device at these or any DD to AGND −0.3 V to +6.5 V other conditions above those indicated in the operational DVDD to DGND −0.3 V to +6.5 V section of this specification is not implied. Exposure to absolute AGND to DGND −0.3 V to +0.3 V maximum rating conditions for extended periods may affect Analog Input Voltage to AGND −0.3 V to AVDD + 0.3 V device reliability. Reference Input Voltage to AGND −0.3 V to AVDD + 0.3 V Digital Input Voltage to DGND −0.3 V to DV
ESD CAUTION
DD + 0.3 V Digital Output Voltage to DGND −0.3 V to DVDD + 0.3 V AIN/Digital Input Current 10 mA Operating Temperature Range −40°C to +105°C Storage Temperature Range −65°C to +150°C Maximum Junction Temperature 150°C TSSOP θJA Thermal Impedance 128°C/W θ JC Thermal Impedance 42°C/W Lead Temperature, Soldering Reflow 260°C Rev. A | Page 7 of 20 Document Outline FEATURES INTERFACE APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING CHARACTERISTICS TIMING DIAGRAM ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS RMS NOISE AND RESOLUTION SPECIFICATIONS ADC CIRCUIT INFORMATION OVERVIEW FILTER, DATA RATE, AND SETTLING TIME GAIN ANALOG INPUT CHANNELS TEMPERATURE SENSOR POWER-DOWN (PDOWN) CLOCK BIPOLAR CONFIGURATION DATA OUTPUT CODING BRIDGE POWER-DOWN SWITCH REFERENCE DIGITAL INTERFACE GROUNDING AND LAYOUT APPLICATIONS INFORMATION WEIGH SCALES EMI RECOMMENDATIONS OUTLINE DIMENSIONS ORDERING GUIDE
