Datasheet AD9054A (Analog Devices) - 3
Description8-Bit, 200 MSPS/135 MSPS A/D Converter
Pages / Page21 / 3 — AD9054A–SPECIFICATIONS. ELECTRICAL CHARACTERISTICS (VDD = 5 V, external …
RevisionD
File Format / SizePDF / 365 Kb
AD9054A–SPECIFICATIONS. ELECTRICAL CHARACTERISTICS (VDD = 5 V, external reference, fS = max unless otherwise noted.). Test
AD9054A–SPECIFICATIONS ELECTRICAL CHARACTERISTICS (VDD = 5 V, external reference, fS = max unless otherwise noted.) Test
AD9054A–SPECIFICATIONS ELECTRICAL CHARACTERISTICS (VDD = 5 V, external reference, fS = max unless otherwise noted.) Test AD9054ABST-200 AD9054ABST-135 Parameter Temp Level Min Typ Max Min Typ Max Unit
RESOLUTION 8 8 Bits DC ACCURACY Differential Nonlinearity 25°C I ±0.9 +1.5/–1.0 ±0.9 +1.5/–1.0 LSB Full VI ±1.0 +2.0/–1.0 ±1.0 +2.0/–1.0 LSB Integral Nonlinearity 25°C I ±0.6 ±1.5 ±0.6 ±1.5 LSB Full VI ±0.9 ±2.0 ±0.9 ±2.0 LSB No Missing Codes Full VI Guaranteed Guaranteed Gain Error1 25°C I ± 2 ± 7 ± 2 ± 7 % FS Gain Tempco1 Full V 160 160 ppm/°C ANALOG INPUT Input Voltage Range (With Respect to AIN) Full V ±512 ±512 mV p-p Compliance Range AIN or AIN Full V 1.8 3.2 1.8 3.2 V Input Offset Voltage 25°C I ± 4 ±16 ± 4 ±16 mV Full VI ± 8 ±19 ± 8 ±19 mV Input Resistance 25°C I 36 62 36 62 kΩ Full VI 23 23 kΩ Input Capacitance 25°C V 4 4 pF Input Bias Current 25°C I 25 50 25 50 µA Full VI 75 75 µA Analog Bandwidth, Full Power2 25°C V 350 350 MHz REFERENCE OUTPUT Output Voltage Full VI 2.4 2.5 2.6 2.4 2.5 2.6 V Temperature Coefficient Full V 110 110 ppm/°C SWITCHING PERFORMANCE Maximum Conversion Rate (fS) Full VI 200 135 MSPS Minimum Conversion Rate (fS) Full IV 25 25 MSPS Encode Pulsewidth High (tEH) 25°C IV 2.0 22 3.0 22 ns Encode Pulsewidth Low (tEL) 25°C IV 2.0 22 3.0 22 ns Aperture Delay (tA) 25°C V 0.5 0.5 ns Aperture Uncertainty (Jitter) 25°C V 2.3 2.3 ps rms Data Sync Setup Time (tSDS) 25°C IV 0 0 ns Data Sync Hold Time (tHDS) 25°C IV 0.5 0.5 ns Data Sync Pulsewidth (tPWDS) 25°C IV 2.0 2.0 ns Output Valid Time (tV)3 Full VI 2.7 5.1 2.7 5.7 ns Output Propagation Delay (tPD)3 Full VI 5.9 7.9 7.5 8.5 ns DIGITAL INPUTS HIGH Level Current (IIH)4 Full VI 500 625 500 625 µA LOW Level Current (IIL)4 Full VI 500 625 500 625 µA Input Capacitance 25°C V 3 3 pF DIFFERENTIAL INPUTS Differential Signal Amplitude (VID) Full IV 400 400 mV HIGH Input Voltage (VIHD) Full IV 1.5 VDD 1.5 VDD V LOW Input Voltage (VILD) Full IV 0 VDD – 0.4 0 VDD – 0.4 V Common-Mode Input (VICM) Full IV 1.5 1.5 V DEMUX INPUT HIGH Input Voltage (VIH) Full IV 2.0 VDD 2.0 VDD V LOW Input Voltage (VIL) Full IV 0 0.8 0 0.8 V DIGITAL OUTPUTS HIGH Output Voltage (VOH) Full VI 2.4 2.4 V LOW Output Voltage (VOL) Full VI 0.4 0.4 V Output Coding Binary Binary –2– REV. D
