Datasheet ADA4960-1 (Analog Devices) - 10
Description5 GHz, Low Distortion ADC Driver/Line Driver
Pages / Page21 / 10 — ADA4960-1. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. AV = 18dB. AV …
File Format / SizePDF / 509 Kb
ADA4960-1. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. AV = 18dB. AV = 6dB. √Hz V/. AV = 12dB. (n Y T. V = 12dB. ( V. ISE D. N L. A R
ADA4960-1 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS AV = 18dB AV = 6dB √Hz V/ AV = 12dB (n Y T V = 12dB ( V ISE D N L A R
VCC = 5 V, VOCM = 2.5 V, RL = 100 Ω differential, AV = 6 dB, CL = 1 pF differential, f = 140 MHz, T = 25°C.
20 18 AV = 18dB AV = 6dB ) 15 16 √Hz V/ AV = 12dB (n Y T 10 SI 14 B) EN A d V = 12dB ( V AV = 6dB A ISE D 5 O 12 N L AV = 18dB A R A T V = 0dB 0 10 SPEC –5 8 0.01 0.1 1 10
004
50 100 1000
039
FREQUENCY (GHz)
08458-
FREQUENCY (MHz)
08458- Figure 5. Small Signal Frequency Response, Figure 8. RTO Noise Spectral Density vs. Frequency at Gain vs. Frequency at AV = 0 dB, AV = 6 dB, AV = 12 dB, and AV = 18 dB AV = 6 dB, AV = 12 dB, and AV = 18 dB
0.6 1.2 AV = 6dB A 1.0 V = 6dB 0.4 0.8 AV = 18dB AV = 18dB A 80% 0.6 V = 12dB 80% 0.2 0.4 AV = 12dB 0.2 (V) (V) 0 0 UT UT O A O AV (dB) SLEW RATE (V/µs) V V (dB) SLEW RATE (V/µs) V –0.2 6 7200 6 8700 –0.2 12 4900 –0.4 12 7700 18 3700 18 6600 20% –0.6 20% –0.4 –0.8 –1.0 –0.6 –1.2 –0.2 0 0.2 0.4 0.6
053
–0.2 0 0.2 0.4 0.6 0.8 1.0
054
TIME (ns) TIME (ns)
08458- 08458- Figure 6. Rise Time, V Figure 9. Rise Time, V OUT vs. Time, VOUT = 1 V p-p OUT vs. Time, VOUT = 2 V p-p
24 13 AV = 6dB 12 22 AV = 6dB ) AV = 18dB 11 dB ( 20 E R B) d 10 AV = 12dB FIGU 1 ( A E V = 12dB P 18 OIS N 9 16 A 8 V = 18dB 14 7 0 200 400 600 800 1000 1200
007 038
100 200 300 400 500 600 700 800 900 1000 FREQUENCY (MHz) FREQUENCY (MHz)
08458- 08458- Figure 7. Noise Figure vs. Frequency at A Figure 10. P1dB vs. Frequency at A V = 6 dB, AV = 12 dB, and AV = 18 dB V = 6 dB, AV = 12 dB, and AV = 18 dB Rev. A | Page 8 of 19 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Absolute Maximum Ratings Thermal Resistance Maximum Power Dissipation ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Test Circuits Circuit Description Basic Structure Applications Information Basic Connections Input and Output Interfacing Gain Adjust Bandwidth Extension ADC Interfacing Line Driver Applications Overdrive and Recovery Layout, Grounding, and Bypassing Outline Dimensions Ordering Guide
