Datasheet AD8138-EP (Analog Devices) - 6
DescriptionLow Distortion Differential ADC Driver
Pages / Page12 / 6 — AD8138-EP. VOCM TO ±OUT SPECIFICATIONS. Table 4. Parameter Conditions. …
File Format / SizePDF / 195 Kb
AD8138-EP. VOCM TO ±OUT SPECIFICATIONS. Table 4. Parameter Conditions. Min. Typ. Max. Unit
AD8138-EP VOCM TO ±OUT SPECIFICATIONS Table 4 Parameter Conditions Min Typ Max Unit
link to page 6 link to page 6 link to page 6 link to page 6
At 25°C, VS = 5 V, VOCM = 2.5 V, G = +1, RL, dm = 500 Ω, unless otherwise noted. All specifications refer to single-ended input and differential output, unless otherwise noted.
Table 4. Parameter Conditions Min Typ Max Unit
DYNAMIC PERFORMANCE −3 dB Bandwidth 220 MHz Slew Rate 250 V/μs INPUT VOLTAGE NOISE (RTI) f = 0.1 MHz to 100 MHz 17 nV/√Hz DC PERFORMANCE Input Voltage Range 1.0 to 3.8 V Input Resistance 100 kΩ Input Offset Voltage VOS, cm = VOUT, cm; VDIN+ = VDIN– = VOCM = 0 V −5 ±1 +5 mV T 1 MIN to TMAX −9.7 +9.7 mV Input Bias Current 0.5 μA VOCM CMRR ΔVOUT, dm/ΔVOCM; ΔVOCM = 2.5 V ± 1 V −70 dB Gain ΔV 1 OUT, cm/ΔVOCM; ΔVOCM = 2.5 V ± 1 V, TMIN to TMAX 0.9968 1 1.0032 V/V POWER SUPPLY Operating Range 2.7 11 V Quiescent Current 15 20 21 mA T 1 MIN to TMAX 10.6 mA Power Supply Rejection Ratio ΔVOUT, dm/ΔVS; ΔVS = ± 1 V −90 −70 dB T 1 MIN to TMAX −57 dB OPERATING TEMPERATURE RANGE −55 +105 °C 1 Specified to ±6 sigma over the −55°C to +105°C operating temperature range. Rev. 0 | Page 6 of 12 Document Outline FEATURES ENHANCED PRODUCT FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATION TYPICAL APPLICATION CIRCUIT TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±DIN TO ±OUT SPECIFICATIONS VOCM TO ±OUT SPECIFICATIONS ±DIN TO ±OUT SPECIFICATIONS VOCM TO ±OUT SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE MAXIMUM POWER DISSIPATION ESD CAUTION MAXIMUM OUTPUT VOLTAGE SWING PIN CONFIGURATION AND FUNCTION DESCRIPTIONS OUTLINE DIMENSIONS ORDERING GUIDE
