Datasheet HMC1030LP5E (Analog Devices) - 4
DescriptionDual RMS Power Detector SMT, Single-Ended, DC - 3.9 GHz
Pages / Page39 / 4 — HMC1030LP5E. DUAL RMS POWER DETECTOR. DC - 3.9 GHz. Electrical …
File Format / SizePDF / 5.0 Mb
HMC1030LP5E. DUAL RMS POWER DETECTOR. DC - 3.9 GHz. Electrical Specifications II,. Modulation Deviation
HMC1030LP5E DUAL RMS POWER DETECTOR DC - 3.9 GHz Electrical Specifications II, Modulation Deviation
HMC1030LP5E
v03.1113
TA = +25 °C, VCCA = VCCB = VCCBS = 5V, Sci3= Sci1 = 0V, Sci2 = 5V, Unless Otherwise Noted Parameter Typ. Typ. Typ. Typ. Typ. Typ. Typ. Units Input Signal Frequency 100 900 1900 2200 2700 3500 3900 MHz
(Output deviation from reference, which is measured with CW input at equivalent input signal power) WCDMA 4 Carrier (TM1-64 DPCH) at +25 °C 0.1 0.1 0.1 0.1 0.1 0.1 0.1 dB WCDMA 4 Carrier (TM1-64 DPCH) at +85 °C 0.2 0.2 0.2 0.2 0.2 0.2 0.2 dB WCDMA 4 Carrier (TM1-64 DPCH) at -40 °C 0.2 0.2 0.2 0.2 0.2 0.2 0.2 dB
RMSA Logarithmic Slope and Intercept
[1] 11 Logarithmic Slope 35.5 38.5 37.3 38.2 40.3 45.8 49.9 mV/dB Logarithmic Intercept -66.4 -65.8 -63.4 -62 -58.9 -53 -49.5 dBm Max. Input Power at ±1 dB Error 10 10 10 10 1 -3 -5 dBm Min. Input Power at ±1 dB Error -62 -62 -60 -58 -56 -51 -47 dBm T
RMSB Logarithmic Slope and Intercept
[1] M Logarithmic Slope 34.7 34.9 36.2 37 38.8 43.6 47.2 mV/dB S Logarithmic Intercept -67.5 -67 -65 -63.5 -60.7 -55.2 -51.7 dBm - Max. Input Power at ±1 dB Error 10 10 10 10 1 -3 -5 dBm Min. Input Power at ±1 dB Error -64 -64 -62 -61 -58 -53 -49 dBm RS
ETA Linear Slope and Intercept
O Linear Slope 14.3 12.3 11.8 10.5 9.1 8.4 V/V T Linear Intercept -65.5 -75.8 -79 -88.2 -102.6 -111.32 mV C Max. Input Power at ±1 dB Error -12 -10 -9 -9 -8 -8 dBm Min. Input Power at ±1 dB Error -31 -30 -29 -28 -27 -27 dBm TE
ETB Linear Slope and Intercept
E Linear Slope 14.5 12.6 12.2 11.1 9.7 8.9 V/V Linear Intercept -64.1 -73.7 -76.1 -82.9 -95.1 -103.7 mV D Max. Input Power at ±1 dB Error -12 -10 -10 -9 -8 -8 dBm R Min. Input Power at ±1 dB Error -31 -30 -29 -28 -27 -27 dBm WE O P [1] With WCDMA 4 Carrier (TM1-64 DPCH) Info F rmoatr p ion rfiurcne is , d hed ebly ivAe n r al y a og D n evd t ice o p s is bla eli c eve o ed t rd o b e e ras: H ccuratite tiatne M d reli iac bl reo . w Ho av wev e C er, n o o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rporation, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106
11 - 3
Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 p o lica rti a o p n S p u s p @ po h rt itt : P ite ho . n c e om : 1-800-ANALOG-D
