Datasheet HMC813LC4B (Analog Devices) - 8
DescriptionSUCCESSIVE DETECTION LOG VIDEO AMPLIFIER (SDLVA) WITH LIMITED RF OUTPUT, 1 - 20 GHz
Pages / Page10 / 8 — HMC813LC4B. SUCCESSIVE DETECTION LOG VIDEO AMPLIFIER (SDLVA). WITH …
File Format / SizePDF / 902 Kb
HMC813LC4B. SUCCESSIVE DETECTION LOG VIDEO AMPLIFIER (SDLVA). WITH LIMITED RF OUTPUT, 1 - 20 GHz. Pad Descriptions
HMC813LC4B SUCCESSIVE DETECTION LOG VIDEO AMPLIFIER (SDLVA) WITH LIMITED RF OUTPUT, 1 - 20 GHz Pad Descriptions
HMC813LC4B
v03.0614
(Continued) Pin Number Function Description Interface Schematic T M S Enable pin, connected to supply voltage for normal - 17 EN operation. Total supply current reduced to less than 3mA when EN is set to 0V. RS O T C E T 20 VCC3 E D Bias supply. Connect supply voltage to these pins with appropriate filtering. R See application circuit. E To ensure proper start-up supply rise time should be faster than 100usec 22, 23 VCC1 W O P Bias supply. Connect supply voltage to this pin with appropriate filtering. 21 VCC2 See application circuit. To ensure proper start-up supply rise time should be faster than 100usec I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com
8
Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r a atio pp n S s u @ p h por ittti : Pte ho.c n o e m : 1-800-ANALOG-D
