Users Guide MCP47X6 (Microchip) - 6
| Manufacturer | Microchip |
| Description | PICtail Plus Daughter Board |
| Pages / Page | 40 / 6 — MCP47X6 PICtail™ Plus Daughter Board User’s Guide. CONVENTIONS USED IN … |
MCP47X6 PICtail™ Plus Daughter Board User’s Guide. CONVENTIONS USED IN THIS GUIDE. DOCUMENTATION CONVENTIONS. Description
MCP47X6 PICtail™ Plus Daughter Board User’s Guide CONVENTIONS USED IN THIS GUIDE
This manual uses the following documentation conventions:
DOCUMENTATION CONVENTIONS Description Represents Examples Arial font:
Italic characters Referenced books MPLAB® IDE User’s Guide Emphasized text ...is the only compiler... Initial caps A window the Output window A dialog the Settings dialog A menu selection select Enable Programmer Quotes A field name in a window or “Save project before build” dialog Underlined, italic text with A menu path File>Save right angle bracket Bold characters A dialog button Click
OK
A tab Click the
tab N‘Rnnnn A number in verilog format, 4‘b0010, 2‘hF1 where N is the total number of digits, R is the radix and n is a digit. Text in angle brackets < > A key on the keyboard Press <Enter>, <F1>
Courier New font:
Plain Courier New Sample source code #define START Filenames autoexec.bat File paths c:\mcc18\h Keywords _asm, _endasm, static Command-line options -Opa+, -Opa- Bit values 0, 1 Constants 0xFF, ‘A’ Italic Courier New A variable argument file.o, where file can be any valid filename Square brackets [ ] Optional arguments mcc18 [options] file [options] Curly brackets and pipe Choice of mutually exclusive errorlevel {0|1} character: { | } arguments; an OR selection Ellipses... Replaces repeated text var_name [, var_name...] Represents code supplied by void main (void) user { ... } DS51932B-page 6 © 2011 Microchip Technology Inc. Document Outline Trademarks Preface Document Revision History Chapter 1. Quick Start Instructions 1.1 Introduction 1.2 Description of the MCP47X6 PICtail™ Plus Daughter Board 1.3 I2C Address Byte for Each Device 1.4 Getting Started With THE Explorer 16 Development Board 1.5 Connecting to the Explorer 16 Starter Kit 1.5.1 Programming the PIC24FJ128 MCU 1.6 Getting Started with PICkit™ Serial Analyzer 1.6.1 PICkit™ Serial Analyzer PC Software Set-Up for the MCP47x6 Daughter Board 1.6.2 Creating Script Files 1.6.3 Verifying the EEPROM Data 1.6.4 Reading both the DAC Register and EEPROM data: 1.7 Examples for Other Devices (MCP4706, MCP4716) 1.8 Programming Example using the PICkit™ Serial Analyzer Appendix A. Schematic and Layouts A.1 Introduction A.2 Board – Schematic A.3 Board – Top Silk and Pads A.4 Board – Top Copper, Top Pads and Top Silk A.5 Board – Bottom Silk and Pads A.6 Board – Bottom Copper, Bottom Pads and Silk Appendix B. Bill Of Materials (BOM) Corporate Office Atlanta Boston Chicago Cleveland Fax: 216-447-0643 Dallas Detroit Indianapolis Toronto Fax: 852-2401-3431 Australia - Sydney China - Beijing China - Shanghai India - Bangalore Korea - Daegu Korea - Seoul Singapore Taiwan - Taipei Fax: 43-7242-2244-393 Denmark - Copenhagen France - Paris Germany - Munich Italy - Milan Spain - Madrid UK - Wokingham Worldwide Sales and Service Worldwide Sales and Service
