Datasheet ADXL103, ADXL203 (Analog Devices) - 5
DescriptionPrecision ±1.7 g, ±5 g, ±18 g Dual-Axis iMEMS® Accelerometer
Pages / Page16 / 5 — Data Sheet. ADXL103/ADXL203. PIN CONFIGURATIONS AND FUNCTION …
RevisionF
File Format / SizePDF / 867 Kb
Data Sheet. ADXL103/ADXL203. PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS. ADXL103. ADXL203. TOP VIEW. (Not to Scale). XOUT. YOUT. COM
Data Sheet ADXL103/ADXL203 PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS ADXL103 ADXL203 TOP VIEW (Not to Scale) XOUT YOUT COM
Data Sheet ADXL103/ADXL203 PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS ADXL103 ADXL203 TOP VIEW TOP VIEW (Not to Scale) (Not to Scale) VS VS 8 8 ST 1 7 XOUT ST 1 7 XOUT +Y NC +X 2 6 NC NC 2 6 YOUT +X COM 3 5 NC COM 3 5 NC 4
002
4
003
NC
03757-
NC
03757-
NOTES NOTES 1. NC = NO CONNECT. DO NOT CONNECT TO THIS PIN. 1. NC = NO CONNECT. DO NOT CONNECT TO THIS PIN.
Figure 3. ADXL103 Pin Configuration Figure 4. ADXL203 Pin Configuration
Table 5. ADXL103 Pin Function Descriptions Table 6. ADXL203 Pin Function Descriptions Pin No. Mnemonic Description Pin No. Mnemonic Description
1 ST Self Test 1 ST Self Test 2 NC Do Not Connect 2 NC Do Not Connect 3 COM Common 3 COM Common 4 NC Do Not Connect 4 NC Do Not Connect 5 NC Do Not Connect 5 NC Do Not Connect 6 NC Do Not Connect 6 YOUT Y Channel Output 7 X 7 X OUT X Channel Output OUT X Channel Output 8 V 8 V S 3 V to 6 V S 3 V to 6 V Rev. E | Page 5 of 16 Document Outline Features Applications General Description Functional Block Diagrams Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics ADXL103 and ADXL203 AD22293 AD22035 and AD22037 All Models Theory of Operation Performance Applications Information Power Supply Decoupling Setting the Bandwidth Using CX and CY Self Test Design Trade-Offs for Selecting Filter Characteristics: The Noise/Bandwidth Trade-Off Using the ADXL103/ADXL203 with Operating Voltages Other than 5 V Using the ADXL203 as a Dual-Axis Tilt Sensor Dual-Axis Tilt Sensor: Converting Acceleration to Tilt Outline Dimensions Ordering Guide Automotive Products
