Datasheet ADXRS290 (Analog Devices)
| Description | Ultralow noise, dual-axis MEMS Gyroscope for Stabilization Applications |
| Pages / Page | 20 / 1 — Ultralow Noise,. Dual-Axis MEMS Gyroscope. Data Sheet. ADXRS290. … |
| Revision | A |
| File Format / Size | PDF / 578 Kb |
Ultralow Noise,. Dual-Axis MEMS Gyroscope. Data Sheet. ADXRS290. FEATURES. GENERAL DESCRIPTION. MEMS pitch and roll rate gyroscope
Ultralow Noise, Dual-Axis MEMS Gyroscope Data Sheet ADXRS290 FEATURES GENERAL DESCRIPTION MEMS pitch and roll rate gyroscope
The ADXRS290 is a high performance MEMS pitch and roll
Ultralow noise: 0.004°/s/√Hz
(dual-axis in-plane) angular rate sensor (gyroscope) designed
High vibration rejection over a wide frequency range
for use in stabilization applications.
Power saving standby mode
The ADXRS290 provides an output ful -scale range of ±100°/s with
80 µA current consumption in standby mode
a sensitivity of 200 LSB/°/s. Its resonating disk sensor structure
Fast startup time from standby mode: <100 ms
enables angular rate measurement about the axes normal to the
Low delay of <0.5 ms for a 30 Hz input at the widest
sides of the package around an in-plane axis. Angular rate data
bandwidth setting
is formatted as 16-bit twos complement and is accessible through
Serial peripheral interface (SPI) digital output
a SPI digital interface. The ADXRS290 exhibits a low noise floor
Programmable high-pass and low-pass filters
of 0.004°/s/√Hz and features programmable high-pass and low-
2000 g powered acceleration survivability
pass filters.
2.7 V to 5.0 V operation −25°C to +85°C operation
The ADXRS290 is available in a 4.5 mm × 5.8 mm × 1.2 mm,
4.5 mm × 5.8 mm × 1.2 mm cavity laminate package
18-terminal cavity laminate package.
APPLICATIONS Optical image stabilization Platform stabilization Wearable products FUNCTIONAL BLOCK DIAGRAM SYNC/ASEL PDMY PDMX AST VDD I/O CP VREG VS POWER GND MANAGEMENT DEMOD PITCH ADC DEMOD FILTERS CONTROL LOGIC ROLL ADC MOSI SERIAL MISO INPUT/OUTPUT SCLK DIGITAL CS ADXRS290 MECHANICAL PITCH SENSOR ROLL PLL DRIVE VELOCITY
001 12636- Figure 1.
Rev. A Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2014 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS RATE SENSITIVE AXES PACKAGE INFORMATION ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION APPLICATION CIRCUIT POWER SUPPLY DECOUPLING POWER SEQUENCING SETTING BANDWIDTH Offset Preservation in the High-Pass Filter ANALOG EVALUATION MODE MECHANICAL CONSIDERATIONS FOR MOUNTING SERIAL COMMUNICATIONS REGISTER MAP REGISTER DESCRIPTIONS ANALOG DEVICES IDENTIFIER MEMS IDENTIFIER DEVICE IDENTIFIER SILICON REVISION NUMBER SERIAL NUMBER (SNx) RATE OUTPUT DATA Register 0x08 to Register 0x0B: DATAX0, DATAX1, DATAY0, and DATAY1 (Read Only) TEMPERATURE DATA Register 0x0C to Register 0x0D: TEMP0 and TEMP1 (Read Only) POWER CONTROL TSM Bit Measurement Bit BAND-PASS FILTER LPF Bits HPF Bits DATA READY Sync Bits RECOMMENDED SOLDERING PROFILE PCB FOOTPRINT PATTERN OUTLINE DIMENSIONS ORDERING GUIDE
