Datasheet MIC4609 (Microchip) - 10
| Manufacturer | Microchip |
| Description | 600V 3-Phase MOSFET/IGBT Driver |
| Pages / Page | 34 / 10 — MIC4609. Note:. = 50 mA. = -50 mA. = GND. 125ºC. EN = V. = V. = 10V. ) … |
| Revision | 03-30-2016 |
| File Format / Size | PDF / 853 Kb |
MIC4609. Note:. = 50 mA. = -50 mA. = GND. 125ºC. EN = V. = V. = 10V. ) 15. 25ºC. Sink. Source (. ONR. = 20V. = 15V. -40ºC. -50. -25. 100. 125. (V)
MIC4609 Note:
Unless otherwise indicated, TA = +25°C with 10V VDD 20V.
25 20 I = 50 mA LO I = -50 mA HO V = GND HS V = GND 125ºC HS EN = V = V EN = V = V V = 10V HB DD DD HB DD 20 ) 15 )
Ω
Ω
25ºC 15 10 Sink Source ( ONR V = 20V ON DD 10 R 5 V = 15V DD -40ºC 5 0 10 11 12 13 14 15 16 17 18 19 20 -50 -25 0 25 50 75 100 125 V (V) Temperature (°C) DD FIGURE 2-13:
LO Output Sink
FIGURE 2-16:
HO Output Source ON-Resistance vs. VDD. ON-Resistance vs. Temperature.
25 25 I = 50 mA LO I = -50 mA LO V = GND HS V = 15V V = GND HS DD 125ºC 20 EN = V = V HB DD EN = V = V HB DD V = 10V DD ) 20 )
Ω Ω
15 25ºC Sink ( 15 10 Source ( ONR V = 20V DD ONR 10 5 -40ºC 0 5 -50 -25 0 25 50 75 100 125 10 11 12 13 14 15 16 17 18 19 20 Temperature (°C) V (V) DD FIGURE 2-14:
LO Output Sink
FIGURE 2-17:
LO Output Source ON-Resistance vs. Temperature. ON-Resistance vs. VDD.
25 25 I = -50 mA I = -50 mA HO LO V = GND V = GND HS HS V = 10V DD EN = V = V EN = V = V HB DD 20 HB DD 20 125ºC V = 15V ) ) DD
Ω Ω
15 15 25ºC Source ( Source ( 10 V = 20V ON ON 10 DD R R 5 -40ºC 5 0 10 11 12 13 14 15 16 17 18 19 20 -50 -25 0 25 50 75 100 125 V (V) Temperature (°C) DD FIGURE 2-15:
HO Output Source
FIGURE 2-18:
LO Output Source ON-Resistance vs. VDD. ON-Resistance vs. Temperature. DS20005531A-page 10 2016 Microchip Technology Inc. Document Outline 600V 3-Phase MOSFET/IGBT Driver Features Typical Applications General Description Package Type Functional Block Diagram MIC4609 – Top Level Circuit Functional Block Diagram MIC4609 – Phase x Drive Circuit Typical Application Circuit MIC4609 – 300V, 3-Phase Motor Driver 1.0 Electrical Characteristics Absolute Maximum Ratings AC/DC Electrical Characteristics Temperature Characteristics 2.0 Typical Performance Curves FIGURE 2-1: VDD Quiescent Current vs. VDD Voltage. FIGURE 2-2: VDD Quiescent Current vs. Temperature. FIGURE 2-3: VHB Quiescent Current vs. VHB Voltage. FIGURE 2-4: VHB Quiescent Current vs. Temperature. FIGURE 2-5: VDD+HB Shutdown Current vs. Voltage. FIGURE 2-6: VDD+HB Shutdown Current vs. Temperature. FIGURE 2-7: VDD+HB Shutdown Current vs. Voltage. FIGURE 2-8: VDD+HB Shutdown Current vs. Temperature. FIGURE 2-9: VDD Operating Current vs. Frequency. FIGURE 2-10: VHB Operating Current vs. Frequency – One Phase. FIGURE 2-11: HO Output Sink ON-Resistance vs. VDD. FIGURE 2-12: HO Output Sink ON-Resistance vs. Temperature. FIGURE 2-13: LO Output Sink ON-Resistance vs. VDD. FIGURE 2-14: LO Output Sink ON-Resistance vs. Temperature. FIGURE 2-15: HO Output Source ON-Resistance vs. VDD. FIGURE 2-16: HO Output Source ON-Resistance vs. Temperature. FIGURE 2-17: LO Output Source ON-Resistance vs. VDD. FIGURE 2-18: LO Output Source ON-Resistance vs. Temperature. FIGURE 2-19: VDD/VHB ULVO vs. Temperature. FIGURE 2-20: Propagation Delay vs. VDD Voltage. FIGURE 2-21: Propagation Delay vs. Temperature. FIGURE 2-22: HO Rise Time vs. VDD Voltage. FIGURE 2-23: HO Fall Time vs. VDD Voltage. FIGURE 2-24: LO Rise Time vs. VDD Voltage. FIGURE 2-25: LO Fall Time vs. VDD Voltage. FIGURE 2-26: Rise/Fall Time vs. Temperature (VDD = 10V). FIGURE 2-27: Rise/Fall Time vs. Temperature (VDD = 20V). FIGURE 2-28: Dead Time vs. VDD Voltage. FIGURE 2-29: Dead Time vs. Temperature (VDD = 10V). FIGURE 2-30: Dead Time vs. Temperature (VDD = 20V). FIGURE 2-31: Overcurrent Threshold vs. VDD Voltage. FIGURE 2-32: Overcurrent Threshold vs. Temperature. FIGURE 2-33: Overcurrent Propagation Delay vs. VDD Voltage. FIGURE 2-34: Overcurrent Propagation Delay vs. Temperature. 3.0 Pin Descriptions TABLE 3-1: Pin Function Table 4.0 Functional Description 4.1 UVLO Protection 4.2 Startup and UVLO FIGURE 4-1: Startup and Fault Timing Diagram. TABLE 4-1: Operational Truth Table 4.3 Enable Inputs 4.4 Input Stage FIGURE 4-2: Input Stage Block Diagram. FIGURE 4-3: Minimum Pulse-Width Diagram. 4.5 Dead Time and Anti-Shoot-Through Protection FIGURE 4-4: Dead Time, Propagation Delay, and Rise/Fall-Time Diagram. 4.6 Low-Side Driver Output Stage FIGURE 4-5: Low-Side Driver Block Diagram. 4.7 High-Side Driver and Bootstrap Circuit FIGURE 4-6: High-Side Driver and Bootstrap Circuit Block Diagram. FIGURE 4-7: MIC4609 Motor Driver Typical Application – Phase A. 4.8 Overcurrent Protection Circuitry FIGURE 4-8: Overcurrent Fault Sequence. EQUATION 4-1: 5.0 Application Information 5.1 Bootstrap Circuit FIGURE 5-1: MIC4609 – Bootstrap Circuit. EQUATION 5-1: EQUATION 5-2: 5.2 HS Node Clamp FIGURE 5-2: Negative HS Pin Voltage. 5.3 Power Dissipation Considerations FIGURE 5-3: MIC4609 High-Side Driving an External IGBT. FIGURE 5-4: Typical Gate Charge vs. VGE. EQUATION 5-3: EQUATION 5-4: EQUATION 5-5: EQUATION 5-6: EQUATION 5-7: 5.4 Decoupling Capacitor Selection 5.5 Grounding, Component Placement and Circuit Layout FIGURE 5-5: Turn-On Current Paths. FIGURE 5-6: Turn-Off Current Paths. 6.0 Packaging Information Appendix A: Revision History Revision A (March 2016) Product Identification System Trademarks Worldwide Sales and Service
