Datasheet MMBF4391, MMBF4392, MMBF4393 (ON Semiconductor) - 2
| Manufacturer | ON Semiconductor |
| Description | N-Channel Switch |
| Pages / Page | 7 / 2 — MMBF4391 / MMBF4392 / MMBF4393. N-Channel Switch. Description |
| Revision | A |
| File Format / Size | PDF / 289 Kb |
N-Channel Switch
G This device is designed for low level analog switching, sample and hold circuits and chopper stabalized
amplifiers. Sourced from process 51. See J111 for
characteristics. S
SOT-23 D Note: Source & Drain
are interchangeable Ordering Information
Part Number Top Mark Package Packing Method MMBF4391 6J SOT-23 3L Tape and Reel MMBF4392 6K SOT-23 3L Tape and Reel MMBF4393 6G SOT-23 3L Tape and Reel Absolute Maximum Ratings(1), (2)
Stresses exceeding the absolute maximum ratings may damage the device. The device may not function or be operable above the recommended operating conditions and stressing the parts to these levels is not recommended. In addition, extended exposure to stresses above the recommended operating conditions may affect device reliability. The
absolute maximum ratings are stress ratings only. Values are at TA = 25°C unless otherwise noted. Symbol Parameter Value Unit VDG Drain-Gate Voltage 30 V VGS Gate-Source Voltage -30 V IGF Forward Gate Current 50 mA -55 to 150 °C TJ, TSTG Operating and Storage Junction Temperature Range Notes:
1. These ratings are based on a maximum junction temperature of 150°C.
2. These are steady-state limits. Fairchild Semiconductor should be consulted on applications involving pulsed or
low-duty-cycle operations. © 1997 Fairchild Semiconductor Corporation
MMBF4391 / MMBF4392 / MMBF4393 Rev. 1.3 www.fairchildsemi.com MMBF4391 / MMBF4392 / MMBF4393 — N-Channel Switch January 2015
