Datasheet OPA1692 (Texas Instruments)
ManufacturerTexas Instruments
DescriptionOPA169x Low-Power, Low-Noise and Low-Distortion SoundPlus Audio Operational Amplifiers
Pages / Page41 / 1 — OPA1692. OPA169x Low-Power, Low-Noise and Low-Distortion. SoundPlus ™ …
OPA1692. OPA169x Low-Power, Low-Noise and Low-Distortion. SoundPlus ™ Audio Operational Amplifiers. 1 Features. 3 Description
Datasheet OPA1692 Texas Instruments
link to page 33 link to page 33 link to page 33 link to page 33 link to page 33 link to page 1 Product Order Technical Tools & Support & Reference Folder Now Documents Software Community Design
OPA1692
SBOS566A – JUNE 2017 – REVISED DECEMBER 2017
OPA169x Low-Power, Low-Noise and Low-Distortion SoundPlus ™ Audio Operational Amplifiers 1 Features 3 Description
• Low Noise: 4.2 nV/√Hz at 1 kHz The OPA169x operational amplifiers achieve a new 1 level of performance for low-power amplifiers with a • Low Distortion: –127 dB at 1 kHz low 4.2-nV/√Hz noise density and distortion of –127 • Low Quiescent Current: dB at 1 kHz. These op amps offer rail-to-rail output 650 µA per Channel swing to within 200 mV of the power supplies with a • Slew Rate: 23 V/μs 2-kΩ load, which increases headroom and maximizes dynamic range. These devices have a high output • Wide Gain Bandwidth: 5.1 MHz drive capability of ±50 mA. • Unity-Gain Stable The OPA169x operational amplifiers operate over a • Rail-to-Rail Output wide supply range of ±1.75 V to ±18 V, or 3.5 V to 36 • Wide Supply Range: V (on 650 µA of supply current per channel), are ±1.75 V to ±18 V, or 3.5 V to 36 V unity-gain stable, and provide excellent dynamic behavior over a wide range of load conditions.
2 Applications
The OPA169x op amps are specified for a • Wireless Microphones temperature range of –40°C to 125°C. • Wireless Audio Monitoring Systems
Device Information(1)
• Portable Radios and Headsets
PART NUMBER PACKAGE BODY SIZE (NOM)
• Portable Audio Effects Processors OPA1692 VSSOP (8) 3.00 mm × 3.00 mm • Portable Recording Systems (1) For all available packages, see the package option addendum • USB Audio Peripherals at the end of the data sheet.
Preamplifier for 3-Wire Electret Microphones THD + N vs Frequency (3 VRMS, 2-kΩ Load)
5 V 5 V 0.1 -60 Primo EM-173 0.1 F ) Competitor A C1 B Microphone R3 0.1 F OPA1692 100 (% Competitor B (d + Microphone Output Competitor C Cable R1 R2 C2 ± Noise 0.01 -80 Noise 5.9 k 100 k 100 pF + OPA1692 + n 0.1 F n -5 V rtio rtio sto 0.001 -100 sto Di R4 100 k Di C3 ic ic 1 F n n R5 1.1 k o o m R6 100 0.0001 -120 m C4 6.8 nF Har Har l l ta ta o o Copyright © 2017, Texas Instruments Incorporated T T 0.00001 -140 10 100 1k 10k Frequency (Hz) C001 1 An IMPORTANT NOTICE at the end of this data sheet addresses availability, warranty, changes, use in safety-critical applications, intellectual property matters and other important disclaimers. PRODUCTION DATA. Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Pin Configuration and Functions 6 Specifications 6.1 Absolute Maximum Ratings 6.2 ESD Ratings 6.3 Recommended Operating Conditions 6.4 Thermal Information: OPA1692 6.5 Electrical Characteristics 6.6 Typical Characteristics 7 Detailed Description 7.1 Overview 7.2 Functional Block Diagram 7.3 Feature Description 7.3.1 Distortion Reduction 7.3.2 Phase Reversal Protection 7.3.3 Electrical Overstress 7.4 Device Functional Modes 7.4.1 Operating Voltage 8 Application and Implementation 8.1 Application Information 8.1.1 Capacitive Loads 8.1.2 Noise Performance 8.1.3 Basic Noise Calculations 8.1.4 EMI Rejection 8.1.5 EMIRR +IN Test Configuration 8.2 Typical Application 8.2.1 Design Requirements 8.2.2 Detailed Design Procedure 8.2.3 Application Curves 8.3 Other Application Examples 8.3.1 Two-Wire Electret Microphone Preamplifier 8.3.2 Battery-Powered Preamplifier for Professional Microphones 9 Power Supply Recommendations 10 Layout 10.1 Layout Guidelines 10.2 Layout Example 10.3 Power Dissipation 11 Device and Documentation Support 11.1 Device Support 11.1.1 Development Support 11.1.1.1 TINA-TI™ (Free Software Download) 11.1.1.2 DIP Adapter EVM 11.1.1.3 Universal Operational Amplifier EVM 11.1.1.4 Smart Amplifier Speaker Characterization Board Evaluation Module 11.1.1.5 TI Precision Designs 11.1.1.6 WEBENCH Filter Designer 11.2 Documentation Support 11.2.1 Related Documentation 11.3 Related Links 11.4 Receiving Notification of Documentation Updates 11.5 Community Resource 11.6 Trademarks 11.7 Electrostatic Discharge Caution 11.8 Glossary 12 Mechanical, Packaging, and Orderable Information
