Datasheet OPA1692 (Texas Instruments) - 4
| Description | OPA169x Low-Power, Low-Noise and Low-Distortion SoundPlus Audio Operational Amplifiers |
| Pages / Page | 41 / 4 — OPA1692. www.ti.com. 6 Specifications. 6.1 Absolute Maximum Ratings. MIN. … |
| File Format / Size | PDF / 1.6 Mb |
OPA1692. www.ti.com. 6 Specifications. 6.1 Absolute Maximum Ratings. MIN. MAX. UNIT. 6.2 ESD Ratings. VALUE
link to page 4 link to page 4
OPA1692
SBOS566A – JUNE 2017 – REVISED DECEMBER 2017
www.ti.com 6 Specifications 6.1 Absolute Maximum Ratings
over operating free-air temperature range (unless otherwise noted)(1)
MIN MAX UNIT
Supply voltage, VS = (V+) – (V–) 40 Voltage V Input (V–) – 0.5 (V+) + 0.5 Input (all pins except power-supply pins) –10 10 mA Current Output short circuit(2) Continuous Operating, TA –55 150 Temperature Junction, T °C J 150 Storage, Tstg –65 150 (1) Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only, which do not imply functional operation of the device at these or any other conditions beyond those indicated under Recommended Operating Conditions. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. (2) Short-circuit to VS/2 (ground in symmetrical dual supply setups), one amplifier per package.
6.2 ESD Ratings VALUE UNIT
Human-body model (HBM), per ANSI/ESDA/JEDEC JS-001(1) ±3000 V(ESD) Electrostatic discharge V Charged-device model (CDM), per JEDEC specification JESD22-C101(2) ±1000 (1) JEDEC document JEP155 states that 500-V HBM allows safe manufacturing with a standard ESD control process. (2) JEDEC document JEP157 states that 250-V CDM allows safe manufacturing with a standard ESD control process.
6.3 Recommended Operating Conditions
MIN NOM MAX UNIT
Single-supply 3.5 36 VS Supply voltage V Split-supply ±1.75 ±18 TA Operating temperature –40 125 °C 4 Submit Documentation Feedback Copyright © 2017, Texas Instruments Incorporated Product Folder Links: OPA1692 Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Pin Configuration and Functions 6 Specifications 6.1 Absolute Maximum Ratings 6.2 ESD Ratings 6.3 Recommended Operating Conditions 6.4 Thermal Information: OPA1692 6.5 Electrical Characteristics 6.6 Typical Characteristics 7 Detailed Description 7.1 Overview 7.2 Functional Block Diagram 7.3 Feature Description 7.3.1 Distortion Reduction 7.3.2 Phase Reversal Protection 7.3.3 Electrical Overstress 7.4 Device Functional Modes 7.4.1 Operating Voltage 8 Application and Implementation 8.1 Application Information 8.1.1 Capacitive Loads 8.1.2 Noise Performance 8.1.3 Basic Noise Calculations 8.1.4 EMI Rejection 8.1.5 EMIRR +IN Test Configuration 8.2 Typical Application 8.2.1 Design Requirements 8.2.2 Detailed Design Procedure 8.2.3 Application Curves 8.3 Other Application Examples 8.3.1 Two-Wire Electret Microphone Preamplifier 8.3.2 Battery-Powered Preamplifier for Professional Microphones 9 Power Supply Recommendations 10 Layout 10.1 Layout Guidelines 10.2 Layout Example 10.3 Power Dissipation 11 Device and Documentation Support 11.1 Device Support 11.1.1 Development Support 11.1.1.1 TINA-TI™ (Free Software Download) 11.1.1.2 DIP Adapter EVM 11.1.1.3 Universal Operational Amplifier EVM 11.1.1.4 Smart Amplifier Speaker Characterization Board Evaluation Module 11.1.1.5 TI Precision Designs 11.1.1.6 WEBENCH Filter Designer 11.2 Documentation Support 11.2.1 Related Documentation 11.3 Related Links 11.4 Receiving Notification of Documentation Updates 11.5 Community Resource 11.6 Trademarks 11.7 Electrostatic Discharge Caution 11.8 Glossary 12 Mechanical, Packaging, and Orderable Information
