Datasheet HMC649ALP6E (Analog Devices) - 4
DescriptionGaAs MMIC 6-Bit Digital Phase Shifter, 3 GHz to 6 GHz
Pages / Page6 / 4 — HMC649ALP6E. GaAs MMIC 6-BIT DIGITAL. PHASE SHIFTER, 3 - 6 GHz. Phase …
File Format / SizePDF / 453 Kb
HMC649ALP6E. GaAs MMIC 6-BIT DIGITAL. PHASE SHIFTER, 3 - 6 GHz. Phase Error vs. State. Absolute Maximum Ratings
HMC649ALP6E GaAs MMIC 6-BIT DIGITAL PHASE SHIFTER, 3 - 6 GHz Phase Error vs State Absolute Maximum Ratings
HMC649ALP6E
v00.0415
GaAs MMIC 6-BIT DIGITAL PHASE SHIFTER, 3 - 6 GHz Phase Error vs. State
15 10 3, 4, 5 GHz T ) 5 ees M 0 (degr R O -5 R R L - S E -10 E S A -15 6 GHz H P ITA -20 IG -25 0 45 90 135 180 225 270 315 360 STATE (degrees)
S - D R Input Power (RFIN) 32 dBm (T= +85 °C)
Bias Voltage & Current
E Bias Voltage Range (Vdd) -0.2 to +12V Vdd Idd T Bias Voltage Range (Vss) +0.2 to -12V 5.0 5.4mA Channel Temperature (Tc) 150 °C IF Vss Iss Thermal Resistance 200 °C/W H -5.0 5.4mA (channel to ground paddle) Storage Temperature -65 to +150 °C
Control Voltage
Operating Temperature -40 to +85 °C E S State Bias Condition ESD Sensitivity (HBM) Class1A (Passed 250V) S Low (0) 0 to 0.2 Vdc A High (1) Vdd ±0.2 Vdc @ 35 µA Typ. H P ELECTROSTATIC SENSITIVE DEVICE OBSERVE HANDLING PRECAUTIONS
Truth Table
Control Voltage Input Phase Shift (Degrees) Bit 1 Bit 2 Bit 3 Bit 4 Bit 5 Bit 6 RFIN - RFOUT 0 0 0 0 0 0 Reference* 1 0 0 0 0 0 5.625 0 1 0 0 0 0 11.25 0 0 1 0 0 0 22.5 0 0 0 1 0 0 45.0 0 0 0 0 1 0 90.0 0 0 0 0 0 1 180.0 1 1 1 1 1 1 354.375 Any combination of the above states will provide a phase shift approximately equal to the sum of the bits selected. *Reference corresponds to monotonic setting Informat F io o n r p furn risihcee d , d by e An lialvoe g rDy a evic n e d t s is o p belie lva e c d t e o o b rd e a e cc rursa: A te a n n a d lo reli g D able. e H v o ic weveers, I no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other nc., 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 • Fax: 978-250-3373 • O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Ph e o r O ne n : 7 -l 81 i-n 3 e a 29-4t w 70 ww 0 • O .h rd iettit r o e nli.c n om license is granted by implication or otherwise under any patent or patent rights of Analog Devices. e at www.analog.com
4
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners.ne: 978-250-33A4 p 3 o plic r a atiopp n S su@ p h po irtttit : Pe. hocno e m : 1-800-ANALOG-D
