Datasheet LT6658 (Analog Devices) - 9
| Description | Precision Dual Output, High Current, Low Noise Voltage Reference |
| Pages / Page | 40 / 9 — Typical perForMance characTerisTics TA = 25°C, VIN = VIN1 = VIN2 = … |
| File Format / Size | PDF / 4.2 Mb |
Typical perForMance characTerisTics TA = 25°C, VIN = VIN1 = VIN2 = VOUT1_F + 2.5V =
LT6658
Typical perForMance characTerisTics TA = 25°C, VIN = VIN1 = VIN2 = VOUT1_F + 2.5V = VOUT2_F + 2.5V except LT6658-1.2 where VIN = VIN1 = VIN2 = 4.5V, COUT1 = COUT2 = 1µF, ILOAD = 0mA, unless otherwise noted. The characteristic curves are similar across the LT6658 family. Curves from the LT6658-1.2, LT6658-2.5 and the LT6658-5 represent the full range of typical performance of all voltage options. Characteristic curves for other output voltages fall between these curves and can be estimated based on their output. 1.2V Line Transient Response 1.2V VOUT1 Current Limit 1.2V VOUT2 Current Limit
400 140 500mV/DIV VIN 350 120 VBYPASS 2mV/DIV 300 100 VOUT1 2mV/DIV 250 80 VOUT2 200 2mV/DIV 60 150 CNR = 1µF VIN = 4.5V TO 5V COUT1 = COUT2 = 1µF ILOAD = 50mA CURRENT LIMIT (mA) CURRENT LIMIT (mA) 40 100 50µs/DIV 6658 G28 20 50 V V IN = 5V IN = 5V V V IN = 10V IN = 10V 0 0 –50 –25 0 25 50 75 100 125 150 –50 –25 0 25 50 75 100 125 150 TEMPERATURE (°C) TEMPERATURE (°C) 6658 G30 6658 G29
2.5V VOUT1 and VOUT2 Output 2.5V VOUT1 Output Voltage 2.5V VOUT2 Output Voltage Voltage vs Temperature with Temperature Drift Temperature Drift 150mA Load on VOUT1
2.502 2.502 2.502 THREE TYPICAL PARTS THREE TYPICAL PARTS ILOAD1 = 150mA 2.501 2.501 2.501 TAGE (V) TAGE (V) TAGE (V) 2.500 2.500 2.500 OUTPUT VOL OUTPUT VOL 2.499 2.499 OUTPUT VOL 2.499 VOUT1 VOUT2 2.498 2.498 2.498 –50 –25 0 25 50 75 100 125 150 –50 –25 0 25 50 75 100 125 150 –50 –25 0 25 50 75 100 125 150 TEMPERATURE (°C) TEMPERATURE (°C) TEMPERATURE (°C) 6658 G31 6658 G32 6658 G33
2.5V VOUT1 Load Regulation, 2.5V VOUT2 Load Regulation, 2.5V VOUT1 Load Regulation, Sourcing Sourcing Sinking
30 20 15 125°C 125°C 25 25°C 25°C –45°C 15 –45°C 10 20 10 15 5 TAGE CHANGE (ppm) 10 TAGE CHANGE (ppm) 5 TAGE CHANGE (ppm) 5 0 0 125°C OUTPUT VOL 0 OUTPUT VOL OUTPUT VOL 25°C –45°C –5 –5 –5 1 10 100 500 1 10 100 1 10 100 OUTPUT CURRENT (mA) LOAD CURRENT (mA) OUTPUT CURRENT (mA) 6658 G34 6658 G35 6658 G36 6658fa For more information www.linear.com/LT6658 9 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Pin Configuration Available Options Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
