Datasheet LT6658 (Analog Devices) - 10
| Description | Precision Dual Output, High Current, Low Noise Voltage Reference |
| Pages / Page | 40 / 10 — Typical perForMance characTerisTics TA = 25°C, VIN = VIN1 = VIN2 = … |
| File Format / Size | PDF / 4.2 Mb |
Typical perForMance characTerisTics TA = 25°C, VIN = VIN1 = VIN2 = VOUT1_F + 2.5V =
LT6658
Typical perForMance characTerisTics TA = 25°C, VIN = VIN1 = VIN2 = VOUT1_F + 2.5V = VOUT2_F + 2.5V except LT6658-1.2 where VIN = VIN1 = VIN2 = 4.5V, COUT1 = COUT2 = 1µF, ILOAD = 0mA, unless otherwise noted. The characteristic curves are similar across the LT6658 family. Curves from the LT6658-1.2, LT6658-2.5 and the LT6658-5 represent the full range of typical performance of all voltage options. Characteristic curves for other output voltages fall between these curves and can be estimated based on their output. 2.5V VOUT2 Load Regulation, Sinking 2.5V Line Regulation VOUT1 2.5V Line Regulation VOUT2
15 2.502 2.502 125°C 25°C –45°C 2.501 2.501 10 2.500 2.500 TAGE (V) TAGE (V) 5 2.499 2.499 TAGE CHANGE (ppm) 2.498 2.498 OUTPUT VOL OUTPUT VOL 0 OUTPUT VOL 2.497 125°C 2.497 125°C 25°C 25°C –40°C –40°C –5 2.496 2.496 1 10 100 0 5 10 15 20 25 30 35 40 0 5 10 15 20 25 30 35 40 OUTPUT CURRENT (mA) INPUT VOLTAGE (V) INPUT VOLTAGE (V) 6658 G37 6658 G38 6658 G39
2.5V Supply Current vs Input 2.5V Output Disable (OD) Low 2.5V Output Accuracy Histogram Voltage Supply Current vs Input Voltage
40 2.5 1.4 35 1.2 2.0 30 1.0 25 1.5 0.8 20 Y CURRENT (mA) 0.6 15 1.0 Y CURRENT (mA) NUMBER OF UNITS 0.4 10 SUPPL SUPPL 0.5 125°C 125°C 5 25°C 0.2 25°C –40°C –40°C 0 0 0 2.4985 2.4990 2.4995 2.5000 2.5005 2.5010 2.5015 0 4 8 12 16 20 24 28 32 36 40 0 4 8 12 16 20 24 28 32 36 40 VOUT1 (V) INPUT VOLTAGE (V) INPUT VOLTAGE (V) 6658 G40 6658 G41 6658 G42
2.5V Minimum VIN to VOUT1 2.5V Minimum VIN to VOUT2 2.5V VOUT1 Power Supply Differential, Sourcing Differential, Sourcing Rejection Ratio vs Frequency
200 100 120 V 100 IN = VIN1 = VIN2 = 6V 100 10 80 10 60 PSRR (dB) 1 1 40 OUTPUT CURRENT (mA) OUTPUT CURRENT (mA) COUT1 = 1µF I 125°C LOAD = 0A 125°C 20 25°C 25°C CNR = 1µF –40°C –40°C CNR = 10µF 0.1 0.1 0 1.1 1.4 1.6 1.9 2.1 1.1 1.3 1.5 1.7 1.9 2.1 0.01 0.1 1 10 100 1000 INPUT–OUTPUT VOLTAGE (V) INPUT–OUTPUT VOLTAGE (V) FREQUENCY (kHz) 6658 G43 6658 G44 6658 G45 6658fa 10 For more information www.linear.com/LT6658 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Pin Configuration Available Options Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
