Datasheet LTM8022 (Analog Devices) - 5
| Description | 1A, 36V DC/DC µModule |
| Pages / Page | 20 / 5 — TYPICAL PERFORMANCE CHARACTERISTICS (TA = 25°C, unless otherwise noted). … |
| File Format / Size | PDF / 283 Kb |
TYPICAL PERFORMANCE CHARACTERISTICS (TA = 25°C, unless otherwise noted). Output Current vs Input Voltage
LTM8022
TYPICAL PERFORMANCE CHARACTERISTICS (TA = 25°C, unless otherwise noted) Output Current vs Input Voltage BIAS Quiescent Current Minimum Required Input Voltage (Output Short) vs Load Current vs Output Load (8VOUT)
3200 16 1200 3000 14 1000 2800 12 800 2600 10 8VOUT 2400 8 600 5VOUT 2200 6 3.3V 400 BIAS CURRENT (mA) OUT LOAD CURRENT (mA) OUTPUT CURRENT (mA) 2000 4 200 1800 2 25°C 85°C 1600 0 0 0 10 20 30 40 0 200 400 600 800 1000 0 10 20 30 40 INPUT VOLTAGE (V) LOAD CURRENT (mA) INPUT VOLTAGE (V) 8022 G10 8022 G11 8022 G13
Minimum Required Input Voltage Minimum Required Input Voltage vs Output Load (5VOUT) vs Output Load (3.3VOUT)
1200 1200 1000 1000 800 800 600 600 400 400 LOAD CURRENT (mA) LOAD CURRENT (mA) 200 200 25°C 25°C 85°C 85°C 0 0 0 10 20 30 40 0 10 20 30 40 INPUT VOLTAGE (V) INPUT VOLTAGE (V) 8022 G14 8022 G15
Temperature Rise vs Load Temperature Rise vs Load Temperature Rise vs Load (3.3VOUT) (5VOUT) (8VOUT)
25 35 40 30 35 20 30 25 25 15 20 24VIN 36VIN 36VIN 36V 20 TURE RISE (°C) IN TURE RISE (°C) 15 10 12V 15 12V IN IN 10 12V 24V IN TEMPERATURE RISE (°C) 24V IN IN TEMPERA TEMPERA 10 5 5 5 0 0 0 0 200 400 600 800 1000 1200 0 200 400 600 800 1000 1200 0 200 400 600 800 1000 1200 LOAD (mA) LOAD (mA) LOAD (mA) 8022 G16 8022 G17 8022 G18 8022fd 5
