Datasheet LT1462, LT1463 (Analog Devices) - 7
DescriptionDual/Quad Micropower, 260µW C-Load Picoampere Bias Current JFET Input Op Amps
Pages / Page12 / 7 — APPLICATIONS INFORMATION. Phase Reversal Protection. (1a). 5.2V Sine …
File Format / SizePDF / 288 Kb
APPLICATIONS INFORMATION. Phase Reversal Protection. (1a). 5.2V Sine Wave. (1b) Typical JFET Input Op Amp with. 5V Supplies
APPLICATIONS INFORMATION Phase Reversal Protection (1a) 5.2V Sine Wave (1b) Typical JFET Input Op Amp with 5V Supplies
LT1462/LT1463
U U W U APPLICATIONS INFORMATION Phase Reversal Protection
response of a competing JFET input op amp in the unity- gain follower mode (Figure 1b) and the response of the Most industry standard JFET input single, dual and quad LT1462/LT1463 (Figure 1c). op amps exhibit phase reversal at the output when the negative common mode limit at the input is exceeded. The phase reversal of Figure 1b can cause lock-up in servo Common mode range is at a premium at ±5V supplies. The systems. The LT1462/LT1463 does not phase-reverse when Figures show a ±5.2V sine wave input (Figure 1a), the the common mode input is anywhere within the supplies. LT1462 • F01a LT1462 • F01b
(1a)
5V Supplies
LT1462 • F01c
(1c) LT1462/LT1463 Output with
5V Supplies Figure 1. Voltage Follower with Input Exceeding the Common Mode Range (VS =
5V)
7
