Datasheet LT6557 (Analog Devices) - 9
Description500MHz, 2200V/µs Gain of 2, Single Supply Triple Video Amplifier with Input Bias Control
Pages / Page12 / 9 — APPLICATIONS INFORMATION. Programmable Input Bias. Shutdown Control
File Format / SizePDF / 615 Kb
APPLICATIONS INFORMATION Programmable Input Bias Shutdown Control
LT6557
no-signal amplifi er input bias condition according to the following relationship: The LT6557 contains circuitry that provides a user-pro- grammed bias voltage to the inputs of all three amplifi er V • . k V PIN sections. The internal biasing feature is designed to mini- BIAS I ( N) = 16 9 1 R mize external component count in AC-coupled applica- SET tions, but may be defeated if external biasing is desired. where VPIN16 = 0.048V typical. Figure 1 shows the simplifi ed equivalent circuit feeding For single 5V supply operation, a 400Ω programming the noninverting input of each amplifi er. A programming resistor is generally optimal. In applications that demand resistor from Pin 16 to GND (Pin 2) establishes the nominal maximum amplifi er linearity, or if external biasing is V+ preferred (in DC-coupled applications, for example), the internal biasing circuitry may be disabled by leaving Pin V 16 open. With Pin 16 open, input loading is approximately I = PIN16 RSET 200kΩ. 2.5k
Shutdown Control
IN 9.1k The LT6557 may be placed into a shutdown mode, where all three amplifi er sections are deactivated and power sup- 6557 F01 ply draw is reduced to approximately 10µA. When the EN pin is left open, an internal 40k pull-up resistor brings the
Figure 1. Simplifi ed Programmable Input Bias Circuit Diagram
pin to V+ and the part enters the shutdown mode. Pulling the pin more than approximately 1.5V below V+ will en- V+ able the LT6557 (see Figure 2 for equivalent circuit). The pull-down current required to activate the part is typically 125µA. In most applications, the EN pin is simply con- 40k nected to ground (for continuous operation) or driven directly by a CMOS-level logic gate (see Figure 3 for examples). Response time is typically 50ns for enabling, BIAS and 1µs for shutdown. In shutdown mode, the feedback CIRCUITRY resistors remain connected between the output pins and EN the individual ground (or V– connected) pins.
Figure 2. Simplifi ed Shutdown Circuit Diagram
V+ V+ 1 EN 1 LT6557 LT6557 DISABLE EN DISABLE 2 2 6557 F03
(3a) Open Drain or Open Collector (3b) CMOS Gate with Shared Supply Figure 3. Suitable Shutdown Pin Drive Circuits
6557fa 9
