Datasheet LT1078, LT1079 (Analog Devices) - 7
DescriptionMicropower, Dual and Quad, Single Supply, Precision Op Amps
Pages / Page20 / 7 — TYPICAL PERFORMANCE CHARACTERISTICS. Input Bias and Offset Currents. …
File Format / SizePDF / 618 Kb
TYPICAL PERFORMANCE CHARACTERISTICS. Input Bias and Offset Currents. Input Bias Current. Supply Current vs Temperature
TYPICAL PERFORMANCE CHARACTERISTICS Input Bias and Offset Currents Input Bias Current Supply Current vs Temperature
LT1078/LT1079
W U TYPICAL PERFORMANCE CHARACTERISTICS Input Bias and Offset Currents Input Bias Current Supply Current vs Temperature vs Temperature vs Common Mode Voltage
55 100 0 V V S = 5V, 0V TO ±15V S = 5V, 0V μA) 50 –2 50 IOS VS = ±15V 45 –4 TA = –55°C 0 T OFFSET CURRENT (pA) A = 25°C 40 –6 TA = 125°C –5 V 35 S = 5V, 0V –8 IB INPUT BIAS CURRENT (nA) –6 30 –10 SUPPLY CURRENT PER AMPLIFIER ( 25 BIAS CURRENT (nA) –7 –12 –50 –25 0 25 50 75 100 125 –50 –25 0 25 50 75 100 125 –1 0 1 2 3 4 TEMPERATURE (°C) TEMPERATURE (°C) COMMON MODE VOLTAGE (V) LT1078/79 • TPC01 LT1078/79 • TPC02 LT1078/79 • TPC03
0.1Hz to 10Hz Noise 0.01Hz to 10Hz Noise Noise Spectrum
1000 TA = 25°C TA = 25°C TA = 25°C VS = ±2.5V V V CHANNEL A S = ±2.5V S = ±2.5V √Hz) √Hz) (AT VS = ±15V 300 CURRENT VOLTAGE NOISE μV/DIV) μV/DIV) NOISE IS 4% LESS CURRENT NOISE IS UNCHANGED) CHANNEL B CHANNEL A 100 0.4μV VOLTAGE NOISE 30 NOISE VOLTAGE (0.4 NOISE VOLTAGE (0.4 VOLTAGE NOISE DENSITY (nV/ CURRENT NOISE DENSITY (fA/ 1/f CORNER CHANNEL B 0.7Hz 10 0 2 4 6 8 10 0 20 40 60 80 100 0.1 1 10 100 1000 TIME (SEC) TIME (SEC) FREQUENCY (Hz) LT1078/79 • TPC06 LT1078/79 • TPC04 LT1078/79 • TPC05
Distribution of Offset Voltage Drift with Temperature (In All Packages Long Term Stability of Two 10Hz Voltage Noise Distribution Except Surface Mount) Representative Units (LT1078)
35 25 15 T 120 T V A = 25°C, VS = 5V, 0V A = 25°C S = 5V, 0V 109 V 30 V V CM = 0.1V S = ± 2.5V CM = 0.1V 10 329 OP AMPS TESTED 20 120 LT1078'S μV) FROM THREE RUNS 70 LT1079'S 1A 25 89 520 OP AMPS 85 5 106 LT1078'S 15 20 45 LT1079'S 0 2B 15 10 47 44 – 5 PERCENT OF UNITS 10 PERCENT OF UNITS 1B 5 OFFSET VOLTAGE CHANGE ( –10 5 2A 4 1 3 5 7 3 1 1 1 0 –15 0 25 30 35 40 –2 –1 0 1 2 0 1 2 3 4 5 VOLTAGE NOISE DENSITY (nV/√Hz) OFFSET VOLTAGE DRIFT WITH TEMPERATURE ( TIME (MONTHS) μV/°C) LT1078/79 • TPC07 LT1078/79 • TPC08 LT078/79 • TPC09 10789fe 7
